After redoing my lower intake for the 3rd time its all sealed up.
Car was fine for about a week. Now randomly it will stop spark and or fuel for about 1-2 seconds then kick back up again. This is random at any rpm and independant of TPS and Maf voltage.
Things Checked:
Maf voltage is good
TPS is good
Fuelrail tight
No fuel leaks
No vacume leaks
O2 sensors are cleared does it when them turned on or off.
Dry gas and fuel injector cleaner in the tank in case i got some bad gas.
Everything is connected good. I have one wire behind the coil that backed out of its casing... not sure what this is but i shoved it back in and seems to be connected, this may be the issue, maybe not.
Possible causes:
Anything attached to the wire harness around the lower intake, injector plugs, dizzy, cap rotar, wires, coil, injectors, fuel pressure regulator. Seems like it could be any of these things even just a dirty or bad connection the last time I put everything back together.
Things Checked:
Maf voltage is good
TPS is good
Fuelrail tight
No fuel leaks
No vacume leaks
Possible causes:
