Intermitent power to fuel pump
T1 3VOM
Maryland
I have intermitent power to the fuel pump in my 1990 LX. It's let me down twice, and all I had to do to get the car running again was to "jiggle" the fusable link near the driver side front wheel. It seems to me that I need to be able to replicate the problem when it's somewhere that I can check it out and see what isn't getting power. The problem is, I haven't been able to do that. Any suggestions on where to go from here?
Backstory: My fuel pump died on me last year while I was driving. I towed it home, and we replaced the fuel pump and spliced the fusable link that had burned through. I started driving it again, and it drove fine for a while. One night (in the rain, of course) it died in the same manner as when the fuel pump went. So, the first thing that came to my mind was a short in the fusable link. I got out and jiggled it, and the car started up. Another time (in the sun this time) I tried to start the car and all it did was crank. So, I opened the hood and jiggled the wire, and it started right up. I checked the splice in the fusable link, and it's fine. So, now, I'm afraid to take my car anywhere for fear that we won't make it home. I can't reproduce the problem just by jiggling the wires, and I don't want to just go replacing relays because I'll never really know that I've fixed it, because it seems to be pretty random when the problem shows up.
Have you replaced the relay under the drivers seat?
That's a known problem for these cars.
Some will work intermittedly, some don't turn off, some don't work at all.
I'm not aware how to test a relay, but i think from ford (and only get the ford one) it's only like $15.
If it's not the answer, throw the spare in the glove compartment.
No, I don't really want to got replacing relays, because I'll never know if that fixed the problem, or if the car is just on good behavior until the next incident. I'm looking for a diagnostic method, I guess.
Edit: Besides, would you think that moving the wires in the engine compartment would really fix the relay under the drivers seat? Doesn't seem that way to me...
Fuel Pump Troubleshooting for 86-90 Mustangs
Clue – listen for the fuel pump to prime when you first turn the ignition switch on.
It should run for 5-20 seconds and shut off. To trick the fuel pump into running,
find the ECC test connector and jump the connector in the lower RH corner to
ground.
attachment.php
If the fuse links are OK, you will have power to the pump. Check fuel pressure –
remove the cap from the Schrader valve behind the alternator and depress the
core. Fuel should squirt out, catch it in a rag. A tire pressure gauge can also be
used if you have one - look for 37-40 PSI. Beware of fire hazard when you do this.
No fuel pressure, possible failed items in order of their probability:
A.) Tripped inertia switch – press reset button on the inertia switch. The hatch
cars hide it under the plastic trim covering the driver's side taillight. Use the
voltmeter or test light to make sure you have power to both sides of the switch
B.) Fuel pump power relay – located under the driver’s seat in most stangs built
before 92. On 92 and later model cars it is located below the Mass Air Flow meter.
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness.
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect
for fuel escaping while pump is running.
The electrical circuit for the fuel pump has two paths, a control path and a power
path.
The control path consists of the inertia switch, the computer, and the fuel pump
relay coil. It turns the fuel pump relay on or off under computer control. The
switched power (red wire) from the ECC relay goes to the inertia switch
(red/black wire) then from the inertia switch to the relay coil and then from the
relay coil to the computer (tan/ Lt green wire). The computer provides the ground
path to complete the circuit. This ground causes the relay coil to energize and
close the contacts for the power path. Keep in mind that you can have voltage
to all the right places, but the computer must provide a ground. If there is no
ground, the relay will not close the power contacts.
The power path picks up from a fuse link near the starter relay. Fuse links are like
fuses, except they are pieces of wire and are made right into the wiring harness.
The feed wire from the fuse link (orange/ light blue wire) goes to the fuel pump
relay contacts. When the contacts close because the relay energizes, the power
flows through the contacts to the fuel pump (light pink/black wire). The fuel pump
has a black wire that supplies the ground to complete the circuit.
Remember that the computer does not source any power to actuators, relays
or injectors, but provides the ground necessary to complete the circuit. That
means one side of the circuit will always be hot, and the other side will go to
ground or below 1 volt as the computer switches on that circuit.
See the following website for some help from Tmoss (diagram designer) &
Stang&2Birds (website host)
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
Now that you have the theory of how it works, it’s time to go digging.
Look for 12 volts at the Orange/Lt. Blue wire (power source for fuel pump relay).
No voltage or low voltage, bad fuse link, bad wiring, bad ignition switch or ignition
switch wiring or connections. There is a mystery connector somewhere under the
driver’s side kick panel, between the fuel pump relay and the fuse link.
Turn on the key and jumper the fuel pump test connector to ground as previously
described. Look for 12 volts at the Light Pink/Black wire (relay controlled power
for the fuel pump). No voltage there means that the relay has failed, or there is a
broken wire in the relay control circuit.
Check the Red/black wire, it should have 12 volts. No 12 volts there, either the
inertia switch is open or has no power to it. Check both sides of the inertia
switch: there should be power on the Red wire and Red/Black wire. Power on the
Red wire and not on the Red/Black wire means the inertia switch is open.
Pump wiring: Anytime the ignition switch is in the Run position and the test
point is jumpered to ground, there should be at least 12 volts present on the
black/pink wire. With power off, check the pump ground: you should see less
than 1 ohm between the black wire and chassis ground.
attachment.php
The Tan/Lt Green wire provides a ground path for the relay power. With the test
connector jumpered to ground, there should be less than .75 volts. Use a test
lamp with one side connected to battery power and the other side to the
Tan/Lt Green wire. The test light should glow brightly. No glow and you have a
broken wire or bad connection between the test connector and the relay. To test
the wiring from the computer, remove the passenger side kick panel and
disconnect the computer connector. It has a 10 MM bolt that holds it in place.
With the test lamp connected to power, jumper pin 22 to ground and the test
lamp should glow. No glow and the wiring between the computer and the fuel
pump relay is bad.
Computer: If you got this far and everything else checked out good, the computer is suspect.
Remove the test jumper from the ECC test connector located under the hood.
Probe computer pin 22 with a safety pin and ground it to chassis. Make sure the computer
and everything else is connected. Turn the ignition switch to the Run position and observe
the fuel pressure. The pump should run at full pressure.
If it doesn't, the wiring between pin 22 on the computer and the fuel pump relay is bad.
If it does run at full pressure, the computer may have failed.
Keep in mind that the computer only runs the fuel pump for about 2-3 seconds when you turn
the key to the Run position. This can sometimes fool you into thinking the computer has died.
Connect one lead of the test light to power and the other lead to computer pin 22 with a safety pin.
With the ignition switch Off, jumper the computer into self test mode like you are going to dump
the codes. Turn the ignition switch to the Run position. The light will flicker when the computer
does the self test routine. A flickering light is a good computer. No flickering light is a bad computer.
If all of the checks have worked OK to this point, then the computer is bad. The
computers are very reliable and not prone to failure unless there has been
significant electrical trauma to the car. Things like lightning strikes and putting
the battery in backwards or connecting jumper cables backwards are about the
only thing that kills the computer.
Fuel pump runs continuously: The tan/green wire has shorted to ground or the relay contacts are sticking.
Disconnect the computer and use an ohmmeter to check out the resistance between the tan/green
wire and ground. You should see more than 10 K Ohms (10,000 ohms) or an infinite open
circuit. Be sure that the test connector isn’t jumpered to ground. If the resistance check is good,
replace the relay.
There is only so many things that control the power to the fuel pump.
If touching the wires fixes the problem, why look anywhere else other than those wires? You hinted that you think the problem is somewhere else in your first statement, but then when i give you another place to look other than those wires, you suggest whatever it is, is related to whatver you touched.
Kinda like you are answering your own question.
I hope I'm not playing the part of the annoying little brats that I've seen in Tech before... but my second post was meant to clarify my question, because I must not have gotten the idea across the first time when I said I don't want to jump to replacing relays straight away. So, I restated that, and then told you what I was wanting.
Here's what I want again. I want to figure out what is wrong with my car. I don't want to replace random (although prone to failure) parts. My car is running now. I probably could have driven it to work everyday this week without a problem. However, it randomly cuts out and leaves me on the side of the road. So if I replace the relay as you suggested, my car will more than likely appear to be ok... temporarily. That doesn't give me warm fuzzies by any stretch of the imagination. I want to find the problem, then fix it, not fix it by hoping I found it. Does that make sense?
Also, I realize that just because that's the way I want to do it, doesn't mean that's the practical way to do it. So, please, don't think I'm not listening to you. I appreciate you taking the time to try to help me with my problem.
I see what you are saying, it's just extremely hard to diagnose a problem that doesn't occur all the time.
I gave you one of the usual suspects, and if the fuel pump is old, that is another.
The touching of the wire sounds to be either the problem or a co-incidence.
I've had relays go bad and fuel pumps, that both gave intermitten operation.
Honestly, i feel that you probably aren't going to find the problem until it occurs on a permanent basis.
That's why i suggested the relay, if you want to know for sure if or if not it was the relay, put the new one in the glove compartment, if it happens again, swap it out, if it starts right up, you know it's the problem, if not, you have a $15 spare for when it does.
If the relay was more expensive, i wouldn't suggest you throw money at it, but it's cheap.
If I remember correctly, the bracket holding the pump relay is designed for two relays so I put my spare right next to the old one. Now, if I have a problem, I just have to unplug the bad one and plug it into the new one next to it.
I agree that it's frustrating to find intermittent problems. It would be nice to do full diagnostics to fix it but that may not work. Sometimes, swap-tronics is the best and fastest way to go.
Good luck!
Jrichker, after reading through that, it seems like a process that I should go through when the car is not running correctly. Am I right in that?
That is correct.
Sometimes dumping the codes will show a code 95 or 96 which point to fuel pump power problems.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See http://www.troublecodes.net/Ford/
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
attachment.php
89 through 95 cars have a working Check Engine light. Watch it instead of a test lamp.
attachment.php
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
