Intermittent Check Engine Light Prob (STILL)
  • Thread starter Thread starter kowalczyk86
  • Start date Start date Jan 17, 2011
kowalczyk86
85
  • Jan 17, 2011
I just changed the O2 sensors. Did not fix the issue. No vac leaks that I can tell. IAC has been changed. Took apart MAF and cleaned it (wasn't even dirty). What else could this be? Code 11's when I run the scanner.
Mustang5L5
Mod Dude
Feb 18, 2001
43,367
18,112
224
Massachusetts
Jan 17, 2011
  • Jan 17, 2011
So when does the light come on? When does it go away?
What sort of scanner are you using to read codes. Does it have a cable that will reach into the cabin with the hood closed.
2000xp8
SN Certified Technician
Aug 8, 2003
8,071
1,655
194
NJ
Jan 17, 2011
  • Jan 17, 2011
I used to have the intermittent check engine light way back, turned out to be the egr.
Cleaned all the carbon and soot out of it and it went away.
kowalczyk86
85
  • Jan 17, 2011
seems like light comes on when it is colder in the morning. It will come on for a couple second then off then repeat. Seems like when I accelerate it comes on. I used a scanner that puts the numbers on the led screen so no room for error. Nothing that will reach the cabin. Car runs and idles perfect.
Mustang5L5
Mod Dude
Feb 18, 2001
43,367
18,112
224
Massachusetts
Jan 17, 2011
  • Jan 17, 2011
Accelerate at WOT? Or part throttle?
kowalczyk86
85
  • Jan 17, 2011
Seems like any throttle. But not every time.
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
  • Gulftown980x
  • Jul 29, 2026
squeak93
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
