I have an AOD-equipped, '89 LX 5.0. Recently, I've been having difficulty starting the car.
This has happened several times. Once, it took place after the car had been sitting for a few hours, but the other times were after I had driven the car for a while. I'll go to start it, turn the key, and it won't crank at all. The usual lights on the dash come up and I'll hear the fuel pump kick on, but nothing else happens.
The following items have either been checked or replaced:
Battery and cables
Fuel pump
Fuel pump relay
Neutral Safety Switch
TFI Module
When the car does finally start (for no apparent reason), it runs normally. It looks like an electrical glitch. The only other things that I can think of that may be causing the problem are the starter solenoid or the ignition switch mechanism.
Any suggestions would be greatly appreciated. Thanks.
Battery and cables
Fuel pump
Fuel pump relay
TFI Module
