I was hoping for a control blade IRS like the one in the Aussie Falcon.
It is cheap, light, and works amazingly well, my stock Focus handles incredibly well thanks to the use of it. Hopefully the special editions whether it's a Mach or a Boss will use it.
But I wouldn't damn the solid axle just yet, when I first heard about it I thought it was a mistake too, but after seeing that it is a proper torque arm/Panhard bar design I think it will work out just fine for the GT.
Remember who started selling aftermarket torque arm/Panhard bar rear suspensions for the Mustang? That's right, Griggs, and those cars handle right with some of the best handling cars in the world. And the set-up supposedly gives a better ride quality than stock Fox cars too. Getting rid of the bind inducing 4 link system and stiff springs needed to keep body roll in check.
So it looks like the 05 Gt will handle great, and ride better at the same time, making the IRS not as important for the GT imo. Also notice the springs ride directly on the axle, eliminating the leverage effect a control arm has on the spring, allowing Ford to use a lower rate spring to achieve the same stiffness as a heavier spring mounted on the control arms, which also contributes to a smoother ride.
And the front suspension finally uses coil over springs, and from what I've read, they copied the strut suspension from the M3. Fixing the nasty geometry problems of the 79-04 cars.
I just can't wait to go out and test drive one once they hit the lots next fall, should ride and handle incredibly well..
