Is a 289 worth building?
budguy211
I got a 289 block (C5AE) that is punched .40 with a stock crank and a comp cam, and that is about it for the block. Is this even worth trying to build or should I just get a roller block and build that one? Thanks for any info.
.040 over is gettin' on the "run hot" side of things with a 289-302. Also if you want to use a 50 oz. 302 one piece rear main seal crankshaft you'll have the old 2 pc./1 pc. crank seal problem. All 289s were 28 oz. balance engines if you use the 289 rotating assy.
Stick with a 80's roller block for headaches sake! :)
:scratch: yeah, the older blocks have a 2pc RMS, but that's what i'm running in mine right now...after 10 years, I still have no leaks-while other friends of mine running the late model 1pc seals are having leaking problems...oh well
the blocks really aren't that much different save for a few things; water passages are different, the main webbing is centered instead of offset like the roller blocks, and the old style has shorter lifter bores...you'd either have to run a flat tappet cam, or do one of the two types of conversions to run a hyd roller...1) run the stock type lifters and spyder with a small base circle cam (~$300), or run the stock type roller cam with the really expensive bar type lifters ($425-$450/set)
but, like several have said-it's gonna be easier to get yourself a roller block
Dbeck002 said:
Build it up, not everyone has a 289. Plus they are just as reliable as the 302.
Oh and they can rev high :nice:
Yes as a matter of fact the old shelbys revved in excess of 8k and made good hp at high RPM. Farly durable too.
build the 289.i had one in a 65 galaxy when i was in high school back in the late 80s and i gave all the new mustangs all they wanted.i miss how hard they rev.i would try to find another block because anything over .030 does make them run alittle warm unless you have a nice radiator/fan combo.
keep your eyes peeled, i got my 302 block w/ pistons, crank, cam, lifters, etc... shortblock for only 250, and its bran new.... they are out there, better off w/ a 302 in my opinion, because so many ppl do them, theres more ppl to answer any of your questions, and a better chance that the answers willbe right....
PauL Perreca
