I say go for it, Iam prety sure all you need is the accessory bracket kit and a intake. The 95 block is set up for the roller cam so you might want to go ahead and do the cam swap. just remember 2 things 1 if you do the cam swap be sure to change the dist gear (steel) and 2 the 351 is 28 oz unbalance (have to use 28oz flywheel and balancer) whoops I thought you had a 351 w truck motor.
