Is a cobra booster needed?
  • Thread starter Thread starter limp
  • Start date Start date May 13, 2022
First Prev 2 of 2
Mustang5L5
Mod Dude
Feb 18, 2001
43,293
17,997
224
Massachusetts
May 14, 2022
#21
  • May 14, 2022
  • #21
Keep in mind, with rear drums the considerations for MC and booster are different than if you were running rear disks. They hydraulic needs of wheel cylinders vs 38mm calipers is different.
There actually isn’t any MC to swap to as the smallest 4wheel disk MC (94 cobra) is still too large for wheel cylinders and will give you a hard pedal.
I often tell folks doing front sn95 brake upgrades to just try it first on the stock MC/booster and see how it feels. Usually it’s pretty darn good.
Rear disks, my answer changes
Reactions: limp
Admin Dude
Jan 4, 1985
43,315
21,488
234
Box behind Walmart
May 14, 2022
#22
  • May 14, 2022
  • #22
General karthief said:
There are threads in the tech/how to thread at the top of the 5.0 tech forum, also look in the resources area for more info on brake master cylinder fitting sizes for 85-93 brake systems, basically you need to update, @Noobz347 had a thread posting cobra booster (for 4 wheel disc) part numbers and if I remember, where to buy them. LMR is not the only place to buy them and likely for less money. I think you can use a common 87 up booster for rear drum/front disc brakes with the proper master cylinder.
I think you could use the lines from a 87-93 mustang along with distribution block from the same 87-93 models with minimal adapters if any.
Can anybody confirm this?
I might have pinned it but the thread you're talking about was probably started by @Mustang5L5 ?
Mustang5L5
Mod Dude
Feb 18, 2001
43,293
17,997
224
Massachusetts
May 14, 2022
#23
  • May 14, 2022
  • #23
I need to rewrite that thread. Next quiet Friday at work.
Reactions: General karthief
General karthief
Mod Dude
Aug 25, 2016
27,998
10,627
213
polk county florida
May 14, 2022
#24
  • May 14, 2022
  • #24
It was about cobra boosters being out of stock and you gave part numbers, I think it was because a member was confused about which one was actually a cobra booster or something or stuff. It used to hang in the tech stickies but I don't recognize it, doesn't matter, he has rear drums on a 9" .
Mustang5L5
Mod Dude
Feb 18, 2001
43,293
17,997
224
Massachusetts
May 14, 2022
#25
  • May 14, 2022
  • #25
93 Cobra Boosters - Don't Get Taken for a Ride
What is the deal with the local parts store selling what they call a brake booster for a 93 cobra for 100$???? I know this cannot be right but what is it? Does anyone know? Has anyone bought one? I asked them to pull up one for my car and it was around the same price, and most of the part...
www.stangnet.com
General karthief
Mod Dude
Aug 25, 2016
27,998
10,627
213
polk county florida
May 14, 2022
#26
  • May 14, 2022
  • #26
That's the one, thanks Mike
not that it applies to limps' car.
Reactions: Shakerhood
96pushrod
I think they're a little easier to get off
5 Year Member
May 15, 2018
1,530
871
133
Savannah
May 14, 2022
#27
  • May 14, 2022
  • #27
I did the pbr fronts with the stock sn95 rear disc on a fox, just ended up using a sn95 booster setup. Slotted the holes a little and massaged the shock tower a touch and it went right in.
Gutted the stock proportioning valve, tapped it for a plug, and used an adjustable one - but I don’t think that’s needed with drums.
I’m with the others that say just try it with a factory booster first though.
Reactions: limp
First Prev 2 of 2
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
Brakes ATS brembos and drums
  • 5ptslow
  • Nov 16, 2025
Fox 5.0 Mustang Tech Apr 4, 2026
AeroCoupe
Y
Brake issues again smh
  • Ybfav84
  • Mar 8, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 10, 2025
DR1962
D
C
Fox Need help identifying brake setup
  • Cypher02xd
  • Apr 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
Mustang5L5
