Is aluminum driveshaft worth it? 2V Mustang GT
Stangg338
23
Utah
Alright so I know we've all seen this mod pop up at some point in time and wondered if it really makes a difference or not. I am on the fence between buying one for my 2001 Mustang GT. At this point, anything helps with my car since it's a convertible with basically full bolt ons and cams haha. I do lots of street driving on the daily and drive my car hard in the city here and there but really like having fun with the car. Would a Ford Performance Aluminum driveshaft be worth it? Anyone have experience with them? Thanks.
I have had one in my 86 saleen for 10 years. It saved 9 lbs over the stock driveshaft. I thought when I swapped them the motor revved quicker. Currently I’m doing the clutch on one of my 96’s. I have an aluminum DS that will go back in. Haven’t weighed the different yet between the two but I will before it goes in. Hope to have it all back together this weekend so I can report back.
Reactions: Stangg338
fwiw, I put one in mine when doing all my upgrades. Weight alone is a plus and didn't feel like putting new u-joints in an old driveline. With a lighter (ATC) flywheel and good clutch it is an excellent match. Can't remember the weight difference but it is quite a bit, plus it looks nice when under the car. :)
Is it worth it... Is there something wrong with your current one? If so, for the cost you can likely have your current one straightened, balanced and new u-joints done for same cost or less. 6 lbs weight savings will not likely do anything performance wise (unless we are talking full blown race car).
Aluminum driveshaft is usually larger diameter than stocker, so it will be a tighter fit.
For the mental placebo to say I have an aluminum driveshaft (or bragging rights at car show) - that's up to you.
I have nothing against them, just being devils advocate and giving the other side of the debate.
