  • 1994 - 1995 Specific Tech
Is Fix-A-Flat Bad?
  • Thread starter Thread starter sade04
  • Start date Start date Sep 6, 2005
sade04
97
Lansdale, PA
Sep 6, 2005
  • Sep 6, 2005
hey guys,
Ive got one tire that slowly leaks air and I have to refill it like every 3 days. All the tires do need replacing but not for another few months or even a year, and i dont want to buy just one new tire. 2 people have told me that fix-a-flat or similar products mess up the rim on the inside and not to use it. What do you guys think? thanks
95opal
5 Year Member
Nov 16, 2004
449
20
39
Sep 6, 2005
  • Sep 6, 2005
find the leak and plug it.leave the fix a flat for the ricers.
VibrantRedGT
"STANGNET'S PENGUIN SMACKER"
424
154
Boca Raton, Florida
Sep 6, 2005
  • Sep 6, 2005
Fix a flat is a pain because it's a temp fix (only designed for a couple of miles) and when you take the tire off now you have a real mess. Will mess up the balance too.
MisterCMK
20+ Year Stangneter
Oct 2, 2004
201
Fargo, ND
Sep 6, 2005
  • Sep 6, 2005
Fix-A-Flat can be explosive too, don't use it. Just have the hole fixed. It will cost ya somethin like 8 bucks.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Sep 6, 2005
  • Sep 6, 2005
Seriously, most texaco's will fix it for 5-10 bucks.
Scott
94gts
873
Carmel, New York
Sep 6, 2005
  • Sep 6, 2005
Scott
my citgo does it for 15
95COBRA241
339
Delray Beach, FL
Sep 6, 2005
  • Sep 6, 2005
Had a small leak in one of my tires. No shop could find the hole using the water test. Used some fix-a-flat, never had the leak any more. Just remember to tell tech about its use prior to him pulling the valve stem. it'll release the chemicals with the air in the tire into the atmosphere.
HISSIN50
34
129
Sep 6, 2005
  • Sep 6, 2005
Seems to me that some of those products are corrosive to some alloys.
skylovia
66
  • Sep 6, 2005
i work at a tire shop and ive NEVER seen a wheel thats been corroded from fix-a-flat. But i will say one thing, be careful with those slow leaks, one day it might get too low and you might have to drive on it, this will cause the sidewalls to get all chewed up and show wires on the INSIDE! this is also called "runflat" damage. Its cheaper to pay for a tire repair than it is to HAVE TO buy a new tire, i see it happen to people all the time at my work.
HISSIN50
34
129
Sep 7, 2005
#10
  • Sep 7, 2005
  • #10
I would suggest some reading or an internet search. The MSDS on some of the flat repair products might change some minds.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Sep 7, 2005
#11
  • Sep 7, 2005
  • #11
I have a chrome rim that will disagree with you, previous owner used some crap like that and now I have on rim corroded and pealing.
94yellowsleeper
45
Bloomington, MN
Sep 7, 2005
#12
  • Sep 7, 2005
  • #12
a lot of times, really slow leaks like that are bead leaks(very common with alloy wheels) if you are unable to find a hole in the tire. try defalting the tire, popping the bead off and putting bead sealer in there. ( your local service station can do it for you too) as for the fix aflat, if you plan on replacing the tires soon, there should be no problem with using it. it will however affect the repairability and balance of the tire, depending on which product you use.
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
A/C Issues
  • Boats90GT
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Mcmahst
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
T
Fox Convertible top issues
  • TDM389
  • Feb 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 15, 2026
General karthief
