  • SN95 4.6L Mustang Tech
Is He Missing Anything?
  • Thread starter Thread starter trombonedemon
  • Start date Start date Mar 18, 2010
trombonedemon
Well-Known Member
Jun 25, 2009
1,962
39
59
U.S.A, U.S.A., U.S.A.!
Mar 18, 2010
  • Mar 18, 2010
replacing your clutch? look no further.
Please comment, is he missing any steps. Would anybody reccomend this that has done a clutch install before.
D-BOI
596
Metro Detro
Mar 18, 2010
  • Mar 18, 2010
man as easy as that sounds i would never attempt to do that without a hoist. ugh it hurts my head just thinking about tackling this
trombonedemon
Well-Known Member
Jun 25, 2009
1,962
39
59
Mar 19, 2010
  • Mar 19, 2010
Yea, I tried pushing my mustang up a slight hill one time, I might as well not even been there. Couldn't imagine if that car would have fallen on someone!
D
Dustys'99
63
Saskatchewan, Canada
Mar 20, 2010
  • Mar 20, 2010
Depending how many miles are on the car and how it looks, I replaced my pivot stud and release lever also the clutch cable. For the amount of money these things cost I think it is worth it. Also don't forget to put some high temp grease on the TOB shaft and a little on the face of the TOB where it contacts the pressure plate. Now might be a good time to replace your tranny output seal as well. To get the tranny back in I had to lift up on the vibration damper at the front of the engine to get the splines of the clutch disc to engage the tranny input shaft. All of this can be done on jack stands, which is the way I did it, but I would never recommend using wood blocks like in the pictures, yikes! If you are filling your tranny through the shifter hole after everything is in, make sure you INSTALL YOUR DRIVESHAFT FIRST. Otherwise your first liter of expensive synthetic ATF will be all over the floor. Now this is the hardest part for some, break in the clutch properly, stop and go traffic, no hard launches, etc.
For anybody looking to do this there is a ton of info out there, I used search on this site as well as google, buy a haynes manual its a cheap investment.
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
  • Gulftown980x
  • Jul 29, 2026
squeak93
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
How do we feel about first gen fuel caps?
  • Teen'93stang5.0
  • Apr 25, 2026
  • Mustang Sound & Shine All
Mustang Sound & Shine All May 3, 2026
General karthief
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
