Is it a immediate problem?
  • Thread starter Thread starter Cobain03
  • Start date Start date Sep 23, 2004
Cobain03
996
Lexington, Ky
Sep 23, 2004
  • Sep 23, 2004
i can hear a...maybe a rocker flappin under the valve covers when i first start the car up on a cold start. is this so important that i should brake it down today? i dont drive the car but to the end of the drive way and back (about a mile round trip), but will be a daily driver come in december. ha ha snow weather and usin it as my DD but i gotta. any suggestions??
V
VictorII
148
Cotati, CA
Sep 25, 2004
  • Sep 25, 2004
Probably just needs adjustment. I keep a spare set of valve covers with the tops cut out for this; and I use neoprene gaskets so they can be reused. Swap the covers and then idle the engine until hot, then back off each rocker nut until it just starts to tap, then take it down until it stops. Then another 3/4 turn, slowly. My guess is that one of the nuts backed out, I've had that happen. It is not serious but should not be left to go very long because the rocker to valve tip surfaces will wear. It is easier to adjust when the engine is not running, but not nearly as accurate in my experience. Takes about an hour. I touch mine up every year.
6Stang7
1,470
Livermore, CA
Sep 25, 2004
  • Sep 25, 2004
Pulling the covers off is a 10 min job, and dealing with the valve train is simple.
Cobain03
996
Lexington, Ky
Sep 25, 2004
  • Sep 25, 2004
pullin mine off is like a 15 min job ha ha i got all my hoses run over top of the covers and stuff oh well at least it looks good
65fastback2+2
1,229
Louisville, KY
Sep 26, 2004
  • Sep 26, 2004
did 289 heads have the adjustable rockers? or are they the "bolt em down as tight as you can get em and go" heads?
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
  • Mindseye007
  • Aug 16, 2026
Mindseye007
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
