Black95GTS
slytherin said:Just wait till all the fall and winter projects start. Everybody is enjoying the summer weather.
Exactly what I was thinking.
GTJake said:Hey Mike,
I might be buying a 75mm "Race" TB. I found a really good deal and I just wanna see the difference from my regular 75mm TB. I think I might do some datalogging of the kg/hr and see if it changes with the swap.
Jake
94TURBO5 O said:Mike
I had the same problem before. I did a lot of searches and found out it was an ignition problem if the o2's start kirk'n out like that also (just another avenue to check). I changed my plugs and they were fouled like a mofo. I had a vacuum leak earlier that day and fouled out the plugs running rich. I changed out the plugs and everything went back to normal. I would just pull the plugs first and check'm out.![]()
Let us know what happens. Any chance of bringing both tb's to the track and comparing? I bet you need to add some fuel with the 75mm race so it may take a few runs to dial it in.
bimmertech said:anyone wanna hear bout inertial supercharging and wave pulse tunig. if so i will post an in depth thread on the stuff you didn't even know was going on in your engine.
Hell yeah get technical.bimmertech said:anyone wanna hear bout inertial supercharging and wave pulse tunig. if so i will post an in depth thread on the stuff you didn't even know was going on in your engine.
Inertial supercharging isn't anything new...it's just how the engine operates. They always have to give it a special name. Kinda like sanitation engineer = garbage man.bimmertech said:anyone wanna hear bout inertial supercharging and wave pulse tunig. if so i will post an in depth thread on the stuff you didn't even know was going on in your engine.
