Finishing up my kenne bell install, put on a new water pump, thermostat, lower intake. Now I'm worried when I start the car and run it I'll have leaks. Anyone else get that feeling? Any horror stories?
This is why I always like to run straight water on first startup. Leaks don’t piss me of as much lol.Finishing up my kenne bell install, put on a new water pump, thermostat, lower intake. Now I'm worried when I start the car and run it I'll have leaks. Anyone else get that feeling? Any horror stories?
I used to worry, but now I use "The Right Stuff" and have never had a leak. I do stress over it though......
I just did a new fuel pump, new fuel lines and I am beyond paranoid that something will "pop loose" and burn my car to the ground.
Chris
Is it normal to be paranoid your gaskets will leak?
Not if you use a good RTV like The Right Stuff or Permatex grey.
Chris
When putting lower intakes on, or any intake, I use long studs in four positions to make sure the intake goes straight down and won't shift anything. When the rest of the bolts are in, the studs get replaced with bolts.I did use "the right stuff" but now I wonder if I didnt put enough on or if I shifted the lower intake too much when lowering it down. Fingers crossed its good.
I'm not cocky just confident in knowing even if it leaks I can fix it.This comes from daily driving my 93 LX for 12.5 years,and all repairs I do need to get done so I can get to work.So far I've been
blessed.
The Right Stuff
