Is It Possible?
  • Thread starter Thread starter ARMAGEDON
  • Start date Start date Jun 6, 2005
ARMAGEDON
100
Jun 6, 2005
  • Jun 6, 2005
For a year, my car has had a wildly surging idle and stall problem. It occurs when the engine is cold or hot. Whenever it wants. It started off occaisional then got progressively worse.
I have done everything on the idle/surge sticky here.
I cleaned the throttle body while it was still on the car by spraying carb cleaner and using a tooth brush.
When I started the car, the idle did seem a bit more constant. I let it run for several minutes and it did not surge or stall. I drove it around for about fifteen minutes and it seemed to run fine. No surging/bucking or stalling.
Is it possible that a dirty thottle body can cause wildly surging idle and stalling?
Thanks for any input.
sgarlic
3,085
Jun 6, 2005
  • Jun 6, 2005
I would think that it certainly is a possibility that if the TB is sticking it could cause stalling. I guess the most important thing is that for now it appears to be fixed, right?
ARMAGEDON
100
Jun 6, 2005
  • Jun 6, 2005
"For Now", but I have had that in the past too. When I get 10 hrs. of drive time with no surging/buking or stalling I will consider it fixed.
Thanks for the input.
D
Daggar
3,902
  • Jun 6, 2005
I would be hunting down vac leaks for beginners. Checkout jrichker's sticky at the top of this forum for other ideas on surging idle problems.
HISSIN50
34
129
Jun 6, 2005
  • Jun 6, 2005
once the adaptive control gets fully adjusted to the new cleanliness, you will know better. Did you clear the KAM after doing all this?
I have run across a car or two that simply would not start with a dirty TB butterfly, but I dont know that it could cause your surging. If it was that dirty, the area around the IAC was likely nasty too - might have been that.
Good luck.
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
Engine Surging idle on start-up
  • keel
  • Aug 11, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
keel
W
1993 LX 5.0 dies after ignition parts replacement
  • Warhorse85
  • Aug 16, 2025
  • 5 6 7
5K
Fox 5.0 Mustang Tech Nov 4, 2025
General karthief
