I know Ford says to use 87 but will it hurt to use 92? Also, does anyone know if Ford uses synthetic oil in these new mustangs?
91mini said:I've only used 93 octane in my stang and have 10,000+ miles on it. I also only go to gas station thst offer gas with additives like Chevron and Shell to help keep the injectors a little cleaner.
GOLDENPONY said:Premium fuel contains more detergents and this will help keep those expensive electronic injectors clean. One last point-many people report getting a few more MPG with premium fuel. Your car will, indeed, run just fine on 87, but if you want to and don't mind the extra cost-go for it.![]()
GOLDENPONY said:Here we go again. I'm sorry but burning high octane fuel will NOT cause any harm-I don't know where this idea came from but it's wrong. That being said, you might not get enough of a gain to justify the extra cost, but it won't hurt anything. I have read in more than one place that the new Spanish Oak computer in our cars will, because of the knock sensor, slightly advance the timing with high octane fuel which is supposed to give maybe 2-3 HP more-certainly not enough to beat your buddy's Z06 but a slight gain. I have experienced something on all 4 of the V-8 Mustangs I have owned and that is the engine idles smoother with premium fuel. Premium fuel contains more detergents and this will help keep those expensive electronic injectors clean. One last point-many people report getting a few more MPG with premium fuel. Your car will, indeed, run just fine on 87, but if you want to and don't mind the extra cost-go for it.![]()
got a specific example to back this up? it would be appreciated.05 GeeTee said:I've read in several places that the Spanish Oak is tuned for 93 and through the use of knock sensors allows you to safely run 87.
