Is it time to replace my spark plugs?
T-Sho
56
I've had my car since it had 8k miles on it. Now its around 76K. I've never changed my spark plugs. Should I look into doing so? The car runs just fine with no indications of any problems (knock on wood). So if it aint broke don't fix it? If I do need to change them what would be an upgrade over the factory plugs (I'm assuming their factory since I don't believe a car with only 8k would have them changed already). Thanks for your help.
i changed mine today just for the heck of it as well as the spark plug wires. i have 129,000 on my stang but i didnt have any problems before hand. its pretty simple to do considering i wouldnt call myself a gear head. it definitely wouldnt hurt to change them tho. seeing as you have a considerable amount of miles less than mine i wouldnt think you would have any trouble if you decide not to change them. i put motorsport plugs with b&b wires. Not the greatest brands lol but they get the job done. :nice:
I replace my plugs every one to two years. Around 15K in between.
I only have 78K on my car and I'm sure the plugs have been replaced at least 7 times in the last 10 years. I'm also on my third set of plug wires.
good god yes it's time!!!, i myself don't go more than 20k before changing. Just get a set of motorcraft's and go to it. use a little tiny dab of anti seize and torque to 14ftlb
:nice: Verrry important. After doing the job, go back under the hood after 500 miles and verify all plugs are still torqued.
Given these engines' general tendency to puke plugs, verifying the torque on them should be considered as routine maintenance on par with oil changes: Every time one gets the oil changed, check the plugs... It may sound anally retentive or obsessive compulsive but it's cheap insurance against a plug blow-out.
