is it worth it?
ponyboy762
32
I found a 91 coupe with nothing but a rear axle for $350. The paint is in good condition but I noticed around the back windsheild, there is a gap about 1/2 an inch on right top and the bottom left inbetween the glass and the trim. Does this mean the frame is twisted, and if it is will it be a problem in the future?
go for it and dont look back, where are you getting that from? i would get it checked out by a mechanic to see what up with it, that is pretty cheap for a car in that kind of condition, what the mileage like?
any other things that will need to be fixed or replaced? i had a 90 GT that i bought in 97 that was pretty beat, and i know what its like to buy a cool car only to need a lot of work to make it perfect. what are you going to use the car for? daily or racer? does it run? strong? it would be pretty cool if you get it, im not sure what your budgets like but if you find yourself in to deep with that then you can unload it for what ever you put into it up to that point. could be pretty cool
