Is my clutch bad?
  • Thread starter Thread starter dec322
  • Start date Start date Jun 12, 2006
D
dec322
401
Bham AL
Jun 12, 2006
  • Jun 12, 2006
Symptoms:
1. Some vibration when I start in first....as if I'm not giving enough gas but I am.
2. Sometimes when rowing through the gears it is sluggish as each gear engages.
3. If I dump the clutch with intentions of spinning the tires, I don't move, the tires don't move, I smell clutch burning, I see smoke from clutch.
4. I started the car yesterday and it started but immediately made a sound as if I turned the key again (I didn't). Then I shut it off but the car continued to try to turn over.....without the key. I guess the starter was stuck...in the engaged position. I pulled the key out, put it back in and started the car right up. No problems (like this) since.
5. With the car off, I can easily row through all the gears (except reverse) without pushing the clutch down.
This is my first manual tranny so I don't know a bad clutch feels like. Thanks.
M
mnbf
207
Canada,Saskatoon
Jun 12, 2006
  • Jun 12, 2006
dec322 said:
Symptoms:
ummm yes your cutch is bad and or someoen didnt adjust it right and the clutch cable is to tight not letting the clutch disengauge
rdharper02
like kicking myself in the junk
703
237
84
Jun 12, 2006
  • Jun 12, 2006
Second on the bad clutch
HISSIN50
34
129
Jun 12, 2006
  • Jun 12, 2006
Where is the point of engagement with the clutch? Unless it's right at the top of the pedal travel (meaning you dont have to hardly push the clutch pedal down in order to change gears), it sounds like the clutch took a poop.
If the clutch has been slipping for some time due to an adjustment issue, it could fry the clutch and lead to all these symptoms.
Good luck.
D
dec322
401
Bham AL
Jun 13, 2006
  • Jun 13, 2006
Good luck.
It is at the top of the pedal. I have tried to adjust it but the FWA stopped turning and i didn't notice a change.....I'll have to get under the car and make sure that nothing is binding.
HISSIN50
34
129
Jun 13, 2006
  • Jun 13, 2006
Just to confirm, you would be tightening the FWA to put some slack into it.
Good luck.
A
anotherstangfan
38
  • Jun 13, 2006
If you want to find out if your clutch is ***** then go for a ride. Drive around and lets say you should be in 3rd gear, well put it in 4th so your car is really low in the rpm range, give it a good amount of gas, if the rpm's climb but you don't go anywhere then you know your clutch is shot. Your car would normally just bog out when you give it gas really low in the rpm range. hope that helps, and if it is your clutch, after you get it replaced don't bother dumping the clutch in order to spin your tires, its just not worth it.
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Engine Which fan clutch ?
  • AnthonyA1234
  • Jun 22, 2026
Fox 5.0 Mustang Tech Sep 19, 2026
Mustang5L5
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
