Is my engine Going??
BlackLX92
27
Oak Harbor, WA
Ok, The other day after a very needed anger burn out, I started to notice that in between 1000 and 2000 rpm when accelerating my engine backfires and jumps now but once above 2000 it is fine and drives like normal. I think I might of half way burned up a ring or something any ideas? Thanks :bang:
Sounds more like a lean backfire then a problem with the timing chain. When you have a sloppy timng chain, while decelerating, it will tend to pop.
I would check your mass air and fuel system.
