Is my starter bad???
SilverBullet00
1,150
Wichita, KS
Here lately I have had some electrical problems. About 2 weeks ago I got in my car to go to work and it wouldnt start. When I turned the key the engine did not turn over but there was a series of loud "electrical-like" clicks. I tried to start it again and the same thing happend. On the third time I heard 2-3 clicks and then the motor turned over. Once it started all my gauges went all the way to the right, sat there for a couple seconds, and went back to normal. Also my radio presets had been wiped out. After this day I hadnt had any problems till a couple days ago.
A couple days ago the engine would fire up, but all my presets would be wiped out. And now last night, the engine wouldnt turn over again, it would only make the loud clicking noise.
Could this be my starter? I know it is sitting pretty close to my headers, but I think there is enough room for the starter to be out of the way. Anyone have any suggestions??
i had the same thing happen to my 96. its not the starter, it's the corrosion on the wires goin to it. i thought it was too the starter, but when i got it off, i noticed that those wires were ****. i just kinda cleand them up a little, and threw them back on. i havnt had the problem since.
it was durning the winter time months also. alot of water and salt. :( poor poo tang :nonono:
Sounds like to me that your battery is dead. You mentions about your radio preset losing it's memory. You needs to alsocheck your battery cables. Make sure there is no corrosion and also check them for tightness. If you have corrosion on them you can clean them up. Remove the battery and have it checked out. If all of this checks out, take alook at the starter wires for corrosion. Always start with the simplest things and go from there. Pearl02.
After looking at some pictures I think it is by the starter, check out this picture. By the way it is deffinetly the starter, solenoid, or starter relay. The thing wont jump start at all! I tried to charge the battery and it did nothing..
so now I need to push start it again and get it in the garage :(
Below is a picture of the jacking points located on the Mustang.
NOTE: Many people will use a floor jack under the differential to lift the entire back of the car up at once, even though the manuals expressly says NOT to do this. People of have done it this way for years with no ill effects. But here is the reason why they tell you not to.
The rear axle is not perfectly straight. To allow the rear end to track correctly, there is about a 1 degree negative camber built into the rear axle. Basically what that means is that instead of axle being parallel with the ground, the differential is a little lower than the center line and the the top of the wheels tilt slightly towards the vehicle.
If you lift the vehicle from the differential, you are putting stress on both left and right axle housings where they meet the differential, at the same time. They were not designed to perform in this manner. Although you may not break anything, you do not want to stress this area or slightly tweak it and remove or reduce this 1 degree negative camber.
NOTE: If you use the wide flat area of the front of the Kframe as a jacking point, be careful. If the jacking plate of your jack is not flat then you run the risk of indenting this area. Doubtful it will cause any complications, but you will hate your self for it later.
FROM http://www.bullittarchive.com/html/modules/articles/article.php?id=76
It is wise when you are installing headers and you have to support your engine from the bottom side. There is also an engine puller holding it up from the top side. Here are some new clues to the problem:
The solenoid is getting 12+ volts but when you try to turn over the motor, the volts drop into the 4-6 range. Also when I turned the car to accessory and turned on my stereo it worked for like 5 seconds, shut off, turned back on for like 2 seconds, then shut off and never came back on. My battery and alternator passed all the pin point tests in the ford technicains maunal, but to me its still sounding like it could be one or both of them?
still sounds to me like a wireing problem. it may not be anything you'd expect either. electricity is a weird thing.
slow96mustang said:
:rlaugh: :lol: :stupid: :owned: :D
that made me laugh very hard. i didnt even notice. i enjoyed that. and good luck with your pan.
Again, I am not jacking up the car in the picture. I am supporting the engine with the floor jack (with a piece of wood) because the k-member was removed. There is also an attatched engine hoist you cant see.
I know good and well not to jack up a car by the oil pan, what I dont know is what this damn electrical problem is :shrug:
Your battery is toast. It will show 12 volts with no load but as soon as you try and run anything(even a stereo) it will drop off quickly. You need to have it load tested. Also check what the voltage is while running,if you can get it running. If you alternator has gone bad you can drive around for up to 2 weeks on just the battery. It should show 14.4 volts or higher while running,around 12.4-12.6 at rest. I have worked at a stereo shop professionaly for 8 years now and see this kind of thing regularily.
I totally agree with this statement. Like I mentioned earlier, have your battery checked. You can take the battery to any part house to do a load test. I had a battery doing the same thing in my wife's Mitsu Eclipse. The battery would show 12.3 volts and amps around 500. Once a "load" was supplied the voltage dropped to 6volts and amps down to 100. Have it checked. If it checks out ok then carry on with some other test. Pearl02.
well it turns out it was a bad starter/solenoid. Cost me 176 bux and 8 hours worth of time to remove/install. Before you put on your longtube headers deffinetely make a heat shield for your solenoid! Its truely challenging to replace a starter/solenoid when you have headers :notnice:
