Holy Crap! No wonder so many people on so many forums have complaints about gear noise. With as many ways to break in (or not) on this thread alone will tell you why.
You must heat cycle gears, about 50 miles will do (although it is recommended 300-500), change the oil and CHECK FOR CONTAMINANTS, add another bottle of friction modifier and then you're good to go. Heat cycling preps the material in a way that can't be done prior to install because the manuf can't actually mesh the gears the way your rearend will.
A "good" install does not compensate for heat cycling the material. Besides, if you have anything other than a good install, you already have problems.
All gears have the possiblity of whining; it's not the gear material (brand), it's the install.
"Lubing" up the gears isn't why you break them in and is not a substitue for heat cycling the material, although they do need lube and are coated after being lapped to ensure oil adheres during the heat cycling process.
jrc_03_gt - those who have not had problems yet are just part of the lucky crowd. Do yourself a favor and just do it.
