ok, i have my car stored for winter covered up with a car cover and under a carport.. it's not exactly inside but it stays out of the elements. the past couple of days it been around 17 degrees out.. 4 days ago i started my car and let it run for a little bit.. i usually do this at least once a week.. it started fine with no problems.
today it is about 49 degrees out and since it had been so cold the past couple nights i figured i'd start her up and let her run.. well i ended up having to jump it because the battery was dead... not totally dead but not enough juice to start the car.. when it started i noticed the tach jumped all the way to 10 grand and the speedometer went all the way 10 150 and all the other gauges pegged but they immediatly went back down then after like a split second the kicked back on to their normal position...
after letting it run a bit i shut it off, restarted it to see if it would do it again and it did...wtf?? i've been in cars that you start and they do this but my car it never did this before.. when i start it it would always just go to the idle rpm's and show the exact amount of fuel and oil pressure... never has it pegged all the guages then reset...
what is making it do this? did my computer screw up over the cold weather or something.... does this happen after our batteries go dead? i hate that it's doing this...any help would be appreciated.. thanks... sorry this was so long
