Is this 5 lug conversion kit good?
  • Thread starter Thread starter BLADDER92FOX
  • Start date Start date Oct 19, 2005
1 of 2 Next Last
BLADDER92FOX
153
Miami
Oct 19, 2005
  • Oct 19, 2005
I was browsing through ebay for a 5 lug conversion kit since i'm on a budget and i found these for a good price:
http://cgi.ebay.com/ebaymotors/ws/e...d=1,1&item=8008427822&sspagename=STRK:MEWA:IT
Anybody buy from these people before on ebay?I just have my bullit rims here sitting in my room and i'm dying to put them on my car soon.
R
rflow50
172
TX
Oct 19, 2005
  • Oct 19, 2005
for the price, seems like a good deal, plus the parts are new. 50resto has this for $370 or so. I will say go for it, but wait for more responses and see what other guys think.
VG30DE
364
Dudley, MA
Oct 19, 2005
  • Oct 19, 2005
I bought everything from mustangs unlimited. Ford Racing rear axles and drums that fit stock everything for around $200
OL' WHITEY
273
Weddington, NC
Oct 19, 2005
  • Oct 19, 2005
Most likely uses the Lincoln rotors which will limit your wheel selection unless you want to run the fronts with no dust caps. There are ways around this, but they involve machining the wheels or rotors, modifying the dust caps or using wheel spacers. This is a hassle and wheel spacers are not the best idea. If you know for a fact that your wheels will fit the Lincoln rotors, then yeah, it's an okay price I guess.
F
fiveohGT
353
Fairfax Virginia
Oct 19, 2005
  • Oct 19, 2005
you should upgrade your brakes while you're at it
RacEoHolic330
I like to dress like a pretty girl
4,014
1,698
203
Allentown, PA
Oct 19, 2005
  • Oct 19, 2005
As said above, those use lincoln rotors which will really limit your wheel selections. That is a good price for what you get though. I did my 5-lug conv. using all sn95 parts. I was able to get the front and rear rotors, calipers (pbr), brackets, spindles and hardware for $350 shipped off the corral. The only other things I had to get were rear axles and e-brake cables. My main intention for doing the 5-lug conversion was so that I could get rid of those hideous drums and actually have brakes that work decently. Having 5-lug was just an added bonus. Its all up to you and your budget though.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Oct 19, 2005
  • Oct 19, 2005
thats a good kit for the $$$ in my opinion , I got junkyard parts and ended up spending 140-150 or so and thats with used parts ....so I say go for it , as for the rotors in front , mr gasket 7/16th wheel spacer is not a big deal , but its more of a chore to find longer studs to fit than anything ....I found some close but they knurl diameter was too small so I broke out the welder and welded the studs to the rotor to keep them from spinning because the knurl diameter was just a little bit smaller and they wouldnt hold tight enough to tighten the wheel up ....but you will be fine if you stay away from ford original equipment or OE replica wheels.....prostars look killer on five lug conversions IMO.........and you wont have to run spacers with them .....
BLADDER92FOX
153
Miami
Oct 19, 2005
  • Oct 19, 2005
Will my original 17x8 bullit rims from ford run on those rotors without modifiying them? If not i know where i can get the axels for cheap and i'll get the rotors elswhere.
BLADDER92FOX
153
Miami
Oct 19, 2005
  • Oct 19, 2005
I found the same guy is selling these axels new for $135.99 and for $29.99 you get 2 new drums,i find that a very good deal. I think i'll go with that for axels.
http://cgi.ebay.com/ebaymotors/ws/e...d=1,1&item=8007573168&sspagename=STRK:MEWA:IT
SitDown
335
Chicagoland
Oct 19, 2005
#10
  • Oct 19, 2005
  • #10
no, they will not directly bolt up to the bullitts...i ran those rotors with my 98 cobra wheels. I needed a 1/4" spacer, could not run centercaps, and only had a few threads that my lugs were holding to. If your set on bullitt wheels id go with a sn95 front setup.
shipping is ~$75, so at $300 i dont think its that great a deal, but still cheaper than buying those individual parts at autozone. You can pick up sn95 spindles rotors calipers and hoses for under 300, then find some axles at a JY. the 28 splines wont hold up to much, so i dont think it matters whether theyre new or used ranger or aerostar units.
plus with the SN setup u have potential cheap 13" brake upgrades and endless wheel selection.
BLADDER92FOX
153
Miami
Oct 19, 2005
#11
  • Oct 19, 2005
  • #11
Well i finally changed my mind,i'm going to have to get the sn95 brake upgrade weather i like it or not cause of the rims. Plus i want better braking anyways. I just have to wait 2 weeks longer to search the junkyards or check online for them. It sux when you get paid every 2 weeks and not enough money also, but it will all happen in due time. So i just need the spindles,hubs,brake lines,rotors and dust shields from a sn95 94-95 v6 or gt right?Do i need the sn95 master cylinder and brake booster too?
SitDown
335
Chicagoland
Oct 19, 2005
#12
  • Oct 19, 2005
  • #12
yes, u have a few option as for MC. Everything ull need to know is here:
http://svo73mm.cjb.net/
Finding the sn95 stuff at a JY would be nice, but just browse around SN, corral, and other ford msg board classifieds. 99+PBR stuff would be better, but u want the 94-95 spindles as the newer spindles have a wider track, but with an 8" wheel they would work too.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Oct 19, 2005
#13
  • Oct 19, 2005
  • #13
yes they will fit , heres a pic of mine , 7/16th spacer and longer studs in front , I actually put the spacers on and drove around for a couple weeks with just them on but didnt like the idea of only have a few threads holding the wheel on so then I opted to put the longer studs in heres a pic
http://www.modularfords.com/gallery/showphoto.php/photo/567/sort/1/cat/all/page/1
BLADDER92FOX
153
Miami
Oct 19, 2005
#14
  • Oct 19, 2005
  • #14
Thanx for the link,it will come in handy.But will i be fine if i keep my master cylinder if i upgrade to 94-95 sn95 brakes?
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Oct 19, 2005
#15
  • Oct 19, 2005
  • #15
nope , you have to upgrade the master cylinder , buy the 3-2 port coversion kit and if you go with the stock sn95 single piston calipers you really arent gonna gain anything worth talking about IMO.......99+ GTs have twin piston aluminum calipers (minor grinding on the spindle required) that are decent but then you are spending even more money on 11 inch brakes .....the cobra upgrades are like $399 everywhere if you wanna do that after you spend the money to put the SN95 spindles on ......by the time you get that one there , then you still have the small power booster on the car which is one major downfall to the whole system from the get go .......
SitDown
335
Chicagoland
Oct 19, 2005
#16
  • Oct 19, 2005
  • #16
I do agree...
Previous to the sn95 setup i ran the lincoln 5lug rotors with m7 73mm calipers and M7 2 port master cyl. This was a very noticble improvement over stock.
Then going to the SN95 setup using the lincoln MC, i didnt see any improvements in braking. If anything i thought the 73mm calipers were better, but possibly a diff MC could have improved my setup.
id still recommend the 94-95 setup over spacers&M7 rotors tho
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Oct 19, 2005
#17
  • Oct 19, 2005
  • #17
LOL, Very True!
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Oct 19, 2005
#18
  • Oct 19, 2005
  • #18
Check out Lukes Site too.
www.mustangmotorsport.com
BLADDER92FOX
153
Miami
Oct 19, 2005
#19
  • Oct 19, 2005
  • #19
Nice fox,do you know if Luke put lowering springs on his car after the billit rims and if he did how much did he drop it. Thanks for the link also might i add.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Oct 19, 2005
#20
  • Oct 19, 2005
  • #20
Luke and I both used a Bullitt Suspension Kit, but he wanted his car to sit a little bit lower than mine and sliced a very small piece off the front Bullitt Springs.
1 of 2 Next Last
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
5 lug rear axles
  • foxbodybill89
  • Sep 11, 2021
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 11, 2021
foxbodybill89
