  • 1994 - 1995 Specific Tech
Is this a good combo?
  • Thread starter Thread starter reddy351
  • Start date Start date Aug 12, 2006
reddy351
560
12
38
Columbus, Ohio
Aug 12, 2006
  • Aug 12, 2006
GT-40 or Explorer upper and lower
Thumper E7's (219/155cfm)
"E" cam (it's an auto)
24# injectors
FlowTech unequal shorties
catless h-pipe
190lph pump
adj fpr
3.73 gears
J-modded trans
CAI
Pretty good package, or not? Am I wrong or is this good for about 270-280hp, to the wheels? I was going to just throw a blower at it but, I've decided that the extra cash can go to dropping it and putting some 17x9/10 wheels and possibly Cobra brakes on it. I'm looking for 13 second ets and a great over-all package. Is there anything I'm forgetting about? Opinions? Anybody running this combo? I'm sure it will need a tune. I think I'll have a chip burned, instead of a tuner.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Aug 12, 2006
  • Aug 12, 2006
You MAY reach that goal
but
When using an auto trans ..................
I've seen they seem to be inconsistent when you use dyno charts to compare their results.
If you had a stick trans ... then I'd say you might reach that goal
IIRC, you got a Tweecer ........... sooooooooooo
You might find 10 to 15 more with it ... depending on parts used
Grady
D
Danman765432
471
Nutley, NJ
Aug 12, 2006
  • Aug 12, 2006
two major things that you are forgetting about are a better torque converter around a 3000 stall, you could get one from Edge Racing for around 600-700 and also your forgetting to get a shift kit. Unless that stuff comes in the J-modded trans which it might. A lot of guys will tell you that you will only get about 260ish hp out of this combo. Thumper heads dont make that great of power put give you good torque. Also you might want to go with something other then flowtech headers, they are kind of the worst made headers from what i have heard. Some heads you might want to look into getting are some edelbrock performer, there aluminum and they also put out number in the range you want. You can also find them pretty cheap from 650-800. If I am wrong with any of this someone just please correct me.
reddy351
560
12
38
Columbus, Ohio
Aug 12, 2006
  • Aug 12, 2006
Where can I get Performer heads for $650-$800? Is that complete?
D
Danman765432
471
Nutley, NJ
Aug 12, 2006
  • Aug 12, 2006
Well they are used but you could pick them up on corral.net
Here is one example: i have seen them for cheaper though
http://www.corral.net/forums/showthread.php?t=817469
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Aug 12, 2006
  • Aug 12, 2006
No heads come complete
You gotta add rockers
If you go stud mounts ...... which are my first choice
you'll need guide plates, and hardned pr's as well
Grady
I
igotyofire
774
Southern California
Aug 12, 2006
  • Aug 12, 2006
Grady
really is that neccessary for afr165s and twisted wedge heads as well?
JJ95GTID
1,141
Phoenix, AZ
Aug 12, 2006
  • Aug 12, 2006
Except for elevation I am in the 13's with stock cam, rockers, pushrods, throttle body, MAF, fpr, and injectors. I paid $724 for the Y303 heads, $300 for the intake and elbow. Just see my sig for my frugal setup. If it ain't there then it is stock.
reddy351
560
12
38
Columbus, Ohio
Aug 12, 2006
  • Aug 12, 2006
I like the frugal build. 13's would make me happy. The torque would be the ideal focus for a street driven car. Maybe I can re-use the OE cam for this combo?
"Complete" when it comes to heads usually means springs, valves, valve seals, etc. In other words, ready to bolt your rockers and (if they fit) use your pushrods and such. I wouldn't expect new heads to come with rockers.
J-mod is a type of "shift kit". It uses the OE valve body plate, modified with different sized holes and replaces some internal parts of the tranny. We'll see how it works. Guys that have it, love it.
Would it make sense to just replace the heads and intake with Explorer parts. I would think I could really save some $$$ with those parts.
I assume that when these cars came from the factory, they made somewhere in the neighborhood of 190rwhp. 260 to the whheels would be a HUGE improvement over that.
Then I could add the supercharger later, to better parts.
Thanks for the input, guys! Keep it coming!
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Aug 12, 2006
#10
  • Aug 12, 2006
  • #10
Not entirely sure but ... I don't think TFS gives you a choice
Just a few reasons ... I don't like ped mounts .........
Not as stable at higher rpms
Not as easily adjustable
No flexability in adjustment without shims/different pr's
You may disagree ... but ... you asked
I believe studs are better and justify the additional cost
Grady
JJ95GTID
1,141
Phoenix, AZ
Aug 12, 2006
#11
  • Aug 12, 2006
  • #11
I agree with Grady on the adjustability of the rockers. Mine do make the infamous ticking noise. The stock PRs are just too short. I bought the shim kit but I will need to get longer PRs to use them. Or, I have been thinking of getting the Steeda shaft mounter rockers with the adjustable PR cups. Kills two birds with one stone by going to a 1.72:1 roller rocker and not needing to get longer PRs.
OrangeMustangGt
1,976
Cape Cod, MA
Aug 12, 2006
#12
  • Aug 12, 2006
  • #12
If i were you, my combo would read like this:
95snoozer's combo.
GT40Ps / Typhoon intake / Comp XE270
he makes 295/321!
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Aug 12, 2006
#13
  • Aug 12, 2006
  • #13
95snoozer's combo.
he makes 295/321!
I gotta agree with Kyle
He has some of the best looking curves for a GT40p head based combo I have seen ....... and I've look at quite a bunch of em
Grady
reddy351
560
12
38
Columbus, Ohio
Aug 13, 2006
#14
  • Aug 13, 2006
  • #14
Ok. How much work has he had to do to the heads? A lot of porting, or what? I can remove smog bumps and do some bowl work. I'm actually pretty adept at that.
I like the price of the Typhoon. In fact, there's one on Ebay, right now with the 94-95 elbow, a 70mm TB and the upper and lower for less than $500. That's right up my alley.
Would the 24's be enough or should I go up a little? Keep the stock MAF? Anything else?
Sounds like the Typoon,GT40P's,XE270 cam,24# inj,NO adj FPR (read that thread) and a tune. Plus the other supporting stuff that I mentioned in the first entry in this thread. Sound right.
Breathing on this side of 300rwhp. Easy mid/low 13's. How is the driveability of that cam?
Thanks a lot for the help guys. For a few more bux (or maybe the same amount) than I was originally planning, I get quite a few more hp. Nice!!!!!
N
SOLD Supercharged 1989 SSP Coupe $13,500 obo
  • notchlubber
  • Jul 17, 2018
13K
Fox Body Mustangs For Sale (1979-93) May 28, 2020
notchlubber
N
1992 5.0 Lx Auto Build Need Help/opinions!!!
  • Stonerboys
  • Aug 20, 2015
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2015
revhead347
AOD combo advice?
  • 5LiterCOOP
  • Feb 3, 2011
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 3, 2011
5LiterCOOP
h/c/i combo opinions wanted
  • BlackVert
  • Jul 19, 2006
1994 - 1995 Specific Tech Sep 18, 2006
BlackVert
Finally, here's my combo... guess my RWHP and track times (Results now posted)
  • Killercanary
  • Sep 23, 2007
  • 2 3 4
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2007
5spd GT
