I am rebuilding the motor in the 5.0. going to be .030. Just wondering if this is a good rebuild kit and a good price?? $550.00 at Summitracing.com
Brand: Federal Mogul
Product Line: Federal Mogul Premium Engine Rebuild Kits
Part Type: Engine Rebuild Kits
Part Number: FEM-MHP173-300
Pistons Included: Yes
Piston Material: Forged aluminum
Piston Style: Flat
Piston Rings Included: Yes
Piston and Ring Oversize (in): 0.030 in.
Piston and Ring Oversize (mm): 0.75mm
Rod Bearings Included: Yes
Rod Bearing Undersize (in): Stock
Rod Bearing Undersize (mm): Stock
Main Bearings Included: Yes
Main Bearing Undersize (in): Stock
Main Bearing Undersize (mm): Stock
Cam Bearings Included: Yes
Gaskets Included: Yes
Oil Pump Included: Yes
Oil Pump Volume: Standard-volume
Oil Pump Pressure: Standard pressure
Oil Pump Drive Shaft Included: No
Freeze Plugs Included: Yes
Camshaft Included: No
Lifters Included: No
Timing Chain and Gears Included: No
Assembly Lubricant Included: Yes
Plastigage Included: Yes
Quantity: Sold as a kit.
Notes: Approximate compression 10.13:1 with a 58.2cc head.
Engine Rebuild, Forged Flat, 4.030 in. Bore, Standard Rod, Standard Main, Ford, 302, Kit
Piston Style: Flat
