is this a Mach?
  • Thread starter Thread starter rc4mike
  • Start date Start date Oct 29, 2006
R
rc4mike
142
  • Oct 29, 2006
Is this an original 69 Mach? Dont have the VIN yet, but owner claims this had a 302 in it...not sure that's the original motor. I thought the Mach's had the side air scoops like this one. Should be getting door plate numbers tomorrow.
thanks
mike
enferno
418
  • Oct 30, 2006
snap a few pics if you can as well
3-0-II
110
Redwood City, CA
Oct 30, 2006
  • Oct 30, 2006
Didn't all '69s have the fake air scoops, save for the Bosses? And I wouldnt get too excited about it having a 302, since they were a very common motor, and available in the run of the mill sportsroofs. I'm assuming you think it is a Mach 1 because of the striping and such?
Either way, run the numbers and find out
Oh and pics would rock
bnickel
5,640
lubbock, texas
Oct 30, 2006
  • Oct 30, 2006
the smallest engine that a 69 mach 1 would have had was a 351 2v windsor. if the car came with a 302 it's not a real mach
R
rc4mike
142
  • Oct 30, 2006
Well, adding the picture would have helped. Sorry, thought i did that. I found the VIN today. It has an "M" in the engine code spot. So that makes it a 351 at least. I guess i assumed that would make it a Mach along with the side scoops?
thanks
bnickel
5,640
lubbock, texas
Oct 30, 2006
  • Oct 30, 2006
well, the m code is a 351 4v so that's at least a good sign. however it looks like it has a new hood, so we can't tell if it had the hood scoop and the hood pins or not which better indicate if it's a mach 1. at this point about the inly way to tell if it's a true mach 1 or not is to order the marti report. www.martiauto.com they will be able to pull the records and find out for sure for you.
actually upon closer inspection that car has the 2 spoke steering wheel not the 3 spoke rim blow that would have come on the mach 1 and i'm also not sure the hood has been changed either now. if those are original to the car it is not a mach 1. just curious, that car wouldn't happen to be in Slaton Texas would it? that fireworks building and some of the other cars look kind of familiar.
chepsk8
2,203
Easton, PA
Oct 31, 2006
  • Oct 31, 2006
Wasn't the base engine a 302? I remember seeing one with one. I know in 70 the 351 wase the base motor.
G
Gud T.B. Blown
583
Oct 31, 2006
  • Oct 31, 2006
I'm not sure if this helps, but on '71-'73 Mach's the two numbers of the VIN before the engine code are 05 designating it as a Mach1 rather than a Sportsroof. Does this also apply to '69 and '70 Mach's as well?
bnickel
5,640
lubbock, texas
Oct 31, 2006
  • Oct 31, 2006
in 69 the base engine was the 351-2v. there was not a seperate code designating the bodystyle as a mach 1, that started in 70. technically, in 69 the mach 1 was an option package just like the GT was.
R
rc4mike
142
#10
  • Oct 31, 2006
  • #10
bnickel
yes it's a new hood, so that does not help.
thanks
cobra443
Indiana
Nov 1, 2006
#11
  • Nov 1, 2006
  • #11
well i have 2 69 mach 1's one a 5 sp and one is auto.. and they were just an upgrade option. all came with the 351W with the side scoops and the hood scoop there should be mach 1 on the passenger side on the glove compartment ill go look in the morning for any other mach 1 only options and let you know
Paint and Body Door Latch Issue
  • KRUISR
  • Oct 9, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
General karthief
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2026
DPP
D
T
What's it Worth? 1970 Mach 1 Q code value
  • tkinak428
  • Apr 13, 2025
  • What is it Worth?!?!?
What is it Worth?!?!? Apr 13, 2025
horse sence
N
Power door lock motor Question
  • NYFox
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
NYFox
N
Strut Tower Help!
  • 93Nifty
  • Jan 10, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 28, 2026
General karthief
