Is this a Mustang computer ?
Markus
238
germany
Hi EEC-IV computer spezialists,
after check the computer number i have
found this number :
E9AF-14A624-AA (GTE)
What is this ? Is this a Mustang computer ?
The car run´s very great and i have no problems.
But i would like to know from which car it is.
thank you guys
Markus
What you have there is a part number. There should be a large 3 or 4 digit number that is larger and stands out more than any of the others on the label. Tell us what that number is.
1990 F350 ford dump 5 speed 460 engine, fuel injected one ton, has the following numbers on it:E9AF 14A624 AA GTE is what I come up with.
Computers are as follows:
87-95 5.0L Mustang
DA1 A9L A9M A9P A9S A9T A3M A3M1 C3W C3W1 X3Z 8LD T4M0 W4H0 U4P0 J4J1
84-85 SVO 2.3L Turbo Mustang
PE PK PK1 PF2 PF3
96-2003 4.6L Mustang & Cobra
Too many to list
94-2001 3.8L Mustang
Too many to list
2003 Mach I
ZYA2
1988-87, 1996-97 Tbirds
LA3 LA2 8AU FTE1
93-95 Lightning
C3P1 C3P2 C3P3 AKC0 VEX1
1999-2000 Lightning
CUX1 CUX2
89-95 SHO Taurus
X2J D4U1
1989 Lincoln Mark VII
D9S
1999 SVT Contour
XGT1
1995-1996 F Series & Econoline
ZJT0 CHC0 MZH0 AHA0 PLC0 RRE0 COD2 WED3 EVE3 FQP0 HZL0 YER2 FEZ3 VUE3
LEM4 WGG0 WAS3 PUG4 SOX4 DPP0 FFX0 TAT4 GLU3 TYY0 GMA0
87-95 5.0L Mustang
PE PK PK1 PF2 PF3
Too many to list
Too many to list
2003 Mach I
ZYA2
LA3 LA2 8AU FTE1
93-95 Lightning
1999-2000 Lightning
CUX1 CUX2
89-95 SHO Taurus
X2J D4U1
D9S
1999 SVT Contour
XGT1
oh man, realy a truck computer?
What advantage or disadvantage have this computer
in a Mustang?
thanks
Markus
in a Mustang?
thanks
Markus
Well if it running ok then I say just leave it. If there is a disadvantage it would be that it would not be compatible with aftermarket chips.
If you wanted to chage it you could go with an A9L. They go for between $100 and $150 used.
Kevin
