Is this Clutch slipping?
Yup. by the way, when the tack would jump it also had a little hesitation and backfire and other times just a complete slip. If I were to drive normal I never would have known it had a problem, but I like to punch it once in a while. I'm glad to leave a thread with a solution to a problem. Hopefully it will help someone.
This would have been good info when you first and subsequently described the problem too. Your earlier description(s) made it sound as if you had ONLY a tachometer indication problem (thus the suggestions you got in response to your question). Indication only problems differ like night and day when full blown ignition system problems. Try and include as many symptoms as you can when you post a problem.
