Killercanary said:Plus the dumb asses only had one rear tie down on the car on the first pull. You should see the dyno graphs from the supra's... its like nothing, nothing, nothing, then a jump of hundreds of HP in only a hundred or so RPM. That's why they often get termed dyno queens because of the way the power band is. I tink it'd be AWEFULLY scarey to drive something with that type of powerband (meaning all the power comes in INSTANTLY when the boost kicks in).
I can't see one (on the first shot), there's one on the second one though.mackey said:Look closer, there is another rear tie blending in.
jwater7 said:So if it all kicks in, at the very last few seconds, wouldn't that mean possible spinout on a track?
That's sick, can't believe that's on a stock block too.
mo_dingo said:The one thing Toyota did right was the supra. It seems the motor is near indestructable (like the 03/04 cobra).
Killercanary said:I will say that my jaw dropped this summer at my home track. A turbo supra like the one above pulled up to the line. It was stock appearing except for what appeared to be 18 or 19" wheels. The as he staged you heard this beast roar to life and WHAM he was off. The thing went a low 11 at 135mph on freaking 18-19" street tires! That impressed the heck out of me!
ROLLIN5.0 said:As for the Supra, I'm pretty sure it's the same motor in the Lexus IS300, just N/A. I've seen some obscene turbo set-ups on them.
Brandon
