is this how?
  • Thread starter Thread starter carbed87
  • Start date Start date Aug 27, 2005
carbed87
215
  • Aug 27, 2005
alright, this is AS FAR AS I KNOW how you adjust valves. fill me in on anything i'm missing and/or doing wrong.
1. with valve covers off, and both intake plenumns off, i start with the number 1 cylinder.
2. starting by turning the crank until the intake valve JUST starts to open, i adjust the exhaust side, by tightening down the rocker, until i see the "plunger" on the lifter depress just a sack hair (about 20 thousands of an inch).
3. rotate crank until the EXHAUST valve just begins to open, and do the exact same thing.
4. and do so to the rest of the cylinders.
5. go through all rockers and tourque them to about 18lbs.
the part i dont get, is shimming them,
why do i need to, what does that mean about my pushrod legnth?
if i need to shim my rockers with more than two shims, does that mean my pushrod is too long or short?
the heads i have are: cast iron gt-40's with pedistul mount rockers.
PLEASE: fill me in on anything that i'm not doing right, ANY help is GREATLY appriciated. thanks
im getting by these heads
Mstng2
789
- - Zion - -
Aug 28, 2005
  • Aug 28, 2005
Ok maybe It's too obvious but I gotta ask... I presume your talking about a solid lifter motor, not a hydraulic lifter motor right??
jeffnoel
1,638
Clovis, CA
Aug 29, 2005
  • Aug 29, 2005
He mentioned a plunger depressing so I don't think so.
Wart
I'm Mad as HELL and I'M not Gonna Take it ANYMORE!
408
NE Ohio
Aug 29, 2005
  • Aug 29, 2005
I figured it was hydraulic from step 2 when it's stated i adjust the exhaust side, by tightening down the rocker, until i see the "plunger" on the lifter depress
Dano78
2,633
Vancouver, WA
Sep 5, 2005
  • Sep 5, 2005
Okay. first off we need to find out EXACTLY what we're working with here. Commonly there are 2 different lengths of pushrods used int he 302 fords. They happen to correspond with the cylinder block that you are using. If you use the wrong pushrods you could cause damage to the valvetrain or just excessive cylinder leakage (depending on the diameter of your cam's base circle)
Anyhow-
1. What year is the engine block? This we MUST know!
2. Where did you get the pushrods from?
3. Shims are only usually offered with aftermarket rockers. Are these aftermarket?
On bolt down style rocker arms, such as yours you don't need a sequence of Intale and Exhaust events to tighten them down. Just install them and torque them 18-20ftlbs.
Now- should you feel that the hydraulic plunger is going too far down into the lifterbody, tha were the shims come into play. but this is only really necessary on fairly large aftermarket cams, usually 280 degree (adv) or 230 degree (@.050) duration cams. If this is the case, I'll have to walk you through the process.
An easy way to tell if you may need shims, make sure your on the backside of the came lobe (or close to) of the valve your're checking. Run the bolt down till you get zero lash and then tighteh an additional 1/2 turn (remember these bolts are course thread and run down farther than the real adjustable's fine threads) Any slop (aka distance) between the pedastal's seat surface and the underside of the pedestal will need about that thickness of shimming. Now this method is just a general way to do it and NOT suggested for you are running a REALLY hot cam. Other tooling and process should be used in that case.
I think idellically you want that littke plunger to go into the lifter bore about .020 to .030 but I've ran tham much deeper than that in my old stupid kid days and didn't have any catastropic problems. Just as long as it doesn't bottom the plunger in the lifter body, though I really do recommend you try to keep it in the above spec.
hope this helps out.
jeffnoel
1,638
Clovis, CA
Sep 5, 2005
  • Sep 5, 2005
I disagree, every instruction sheet that I've read for installing pedestal rockers still requires you to go through a sequence so that your torqueing the bolt only when the valve is closed.
Crane Cams pedestal rocker arm install directions
Dano78
2,633
Vancouver, WA
Sep 7, 2005
  • Sep 7, 2005
Well since he didn't really leave any other specs I just gave him the process out of an 80's model Ford shop manual for a stock type valvetrain, figuring that's probably what it was and it didn't say anything about rolling the engine over, even though it's probably a good idea. I was basicallly suggesting that he not needed to use a solid lifter adjustment sequence to install his hydraulic valvetrain.
Naturally, if you use aftermarket parts you want to check all tolerances, however in all of my past experiences with the large margin of error (even as listed in the tech article you posted) there's plenty of room when using stock or stock replacement components. How else would you do, say an FE engine with a rail rocker setup?
When running a hot cam (warranting much more stout valves prings) it certainly would be wise to roll the engine over onto it's compression stroke when torking down the rockers as the excessive spring pressure could effect the 5/16 bolts' torque measurement if combined with the pressure of opening a valve too.
itsaMustangtoo
292
Carlisle,Pa
Sep 7, 2005
  • Sep 7, 2005
I only have one thing to add. Pick up a chilton because there is a sequence to adjust multiple rockers rather than one cyl. at a time. I used to use it on my solid cammed 460.
New misfire after replacing valve seals/springs.
  • SpeedofDarkness
  • Aug 24, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 24, 2025
SpeedofDarkness
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
G
4.6L rods and piston into a 5.4L
  • Green mustang
  • Jun 11, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jun 11, 2025
Green mustang
G
