Is this normal?
SVT98Snake
258
OK, USA
So I pulled my plugs...
There was no deposits and the wear/shape looked great.......BUT They had a dark red/purple color........
I have never seen this. Is it normal?
I do run 93/101 blend and if I use 91, I use octane boost.
i work for a petroleum company called Royal Petroleum, the discoloration is common among 100+ octane due to the stabaizer they use to prevent pre-detonation of fuel from the compression in high compression projects car in most casses. other times it can be from simple cleaning additives and thinners. Dont worry about it unless you start to see that colored smoke out ur tail pipe, then ur either running too rich or you have a seal break; including blue or white smoke fore oil and water burning
