  • 1994 - 1995 Specific Tech
Is this normal?
  • Thread starter Thread starter 95Vert
  • Start date Start date May 31, 2006
95Vert
1,785
North Mexico (deep south Texas)
May 31, 2006
  • May 31, 2006
Ever since my t-5 swap, my rpms drop between gears. I know it will since I'm putting it into N, but Paul(punisher) was surprised when my RPMS would go down when I pulled out of gear. My idle doesn't hang at all, is that normal? Should I have at least a small amount of hang. It doesn't go dead but the RPMs will come down to 1000.
1TallMF
955
Montreal
May 31, 2006
  • May 31, 2006
Thats odd... Does it do it all the time, even on a WOT run?
95Vert
1,785
May 31, 2006
  • May 31, 2006
Nope. I mean I have no complaints. It drives fine and no problems on WOT either.
94-302-vert
1,947
NE CT
May 31, 2006
  • May 31, 2006
it really depends on how fast it drops RPMs. But it really does sound normal.
Blackened302
1,439
South TX
May 31, 2006
  • May 31, 2006
when i disconnected my IAC, the rpms would immediately drop between shifts like yours does--maybe that's it?
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
May 31, 2006
  • May 31, 2006
I thought you could change the settings in the tweecer, so that they drop much faster than normal. Did you play with those settings? I don't remember which one it is though.
Scott
SVTCobra306
170
Ft. Bragg, NC
May 31, 2006
  • May 31, 2006
You can adjust them via the TwEECer. Mine compression brakes harder than any 5.0 I've ever driven.
Guero
2,148
May 31, 2006
  • May 31, 2006
when my iac was really low, it did the same thing.
95Vert
1,785
Jun 1, 2006
  • Jun 1, 2006
It may be my IAC, but I've got bigger problems now.
BlackVert
5,589
9
98
Bethesda, MD
Jun 1, 2006
#10
  • Jun 1, 2006
  • #10
in the tweecer, the dashpot decay rate is what controls it.
if you haven't touched it, then it could be that your iac is not behaving correctly.
ProKiller
3,064
15
78
PA
Jun 1, 2006
#11
  • Jun 1, 2006
  • #11
i would say its the IAC.
Guero
2,148
Jun 1, 2006
#12
  • Jun 1, 2006
  • #12
what wrong now?
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
Jun 1, 2006
#13
  • Jun 1, 2006
  • #13
Mine hangs right under where It was before I shift.
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
Idler pulley as substitute for Power Steering Pump ?
  • Bhenders
  • Jul 15, 2026
  • Other Auto Tech
Other Auto Tech Jul 16, 2026
LILCBRA
idles perfect then jolts and cuts out when put into Reverse or Drive.
  • shanesstangs
  • Mar 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
General karthief
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
