  • 2005 - 2009 Specific Tech
Is this normal?
  • Thread starter Thread starter bellegt06
  • Start date Start date Aug 31, 2006
bellegt06
52
  • Aug 31, 2006
I recently installed my JTI CAI w/ SCT Tune and the engine rpms drop very slow after i put the car in neutral. If i had to guess i would say the car stays in the 3000-3500 RMP range for 2 secs or so after the clutch is pushed in or i shift to neutral from an acceleration. Is this normal?
Thanks
J
joes snake
154
Ruskin, FL
Aug 31, 2006
  • Aug 31, 2006
I just installed the same kit yesterday and noticed that my RPMs also seem to take a minute to come down; mine also seems to be idling just a bit high.
jberylec
81
  • Aug 31, 2006
That's not normal, you guys should check all connections on the intake to make sure nothing is loose, if it's all good then contact whomever you bought the tunes from...
bellegt06
52
  • Aug 31, 2006
Joe did you purchase yours from JTI direct with the tune from SCT, or did you order form somewhere else like bamachips?
I will double check the connections, but i am pretty sure everything is fine. I think it might be the tune.
frdfrst
178
phoenix az
Aug 31, 2006
  • Aug 31, 2006
sounds like an air leak
J
joes snake
154
Ruskin, FL
Aug 31, 2006
  • Aug 31, 2006
I ordered mine direct from John. I think my idle is just a touch high; I will check for leaks also.
bellegt06
52
  • Aug 31, 2006
If it is an air leak wher is the most likely place it is leaking.
Thanks
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Aug 31, 2006
  • Aug 31, 2006
First thing to do is check for leaks at all the fittings and attachment points of kit.
If all that is fine then the problem is in the tune, you may want to contact the tuner. This was also a problem on the older modular cars 96-04 on those you could change the dashpot setting in the tune and that would correct this problem. I am not sure on the 05+ cars with the electronic throttle body.. Unfortunatly I don't have a ton of experence with the 05+ processor.
bellegt06
52
  • Aug 31, 2006
Thx. I will double check all fittings tommorrow. Whiel i am very inexperince with mecahnicaly, seems to me that two people having the same experience with the exact same CAI and Tune, it would be more like the the tune than two improper installs.
bellegt06
52
#10
  • Sep 2, 2006
  • #10
I checked all the connections and couldn't find any leaks. I contacted John and he is going to check with Ryan at SCT to see if it could be something in the tune.
Joes Snake, he asked what your computer code to see if it might be related to that. If you could post your code and/or email John with that info it would be helpful.
Thanks
Dennis
J
joes snake
154
Ruskin, FL
Sep 3, 2006
#11
  • Sep 3, 2006
  • #11
Dennis, I talked to John the other day, my car seems to have "settled out" so it's running fine now...hope it stays that way.
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
G
2016 GT, Cold Air/Tune Trouble (overheating) . Advice/Help Please!
  • GLStang
  • Sep 6, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Sep 6, 2025
2008 Mustang Bullitt stuck in Fifth gear
  • Jester67
  • Jul 15, 2025
2005 - 2014 S-197 Mustang -General/Talk- May 27, 2026
Jester67
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
