  • SN95 4.6L Mustang Tech
is this normal???
  • Thread starter Thread starter 2003_GT
  • Start date Start date Dec 12, 2008
2003_GT
69
Santa Fe, NM
Dec 12, 2008
  • Dec 12, 2008
Ok so when i turn off my car everyday, there is this gurguling sound that comes from the front side of the passanger side, usually happens when it is warm...
Car runs fine, a little slugish now and then but seems to be running strong.
I dont know if this girgulling sound is normal or not just trying to make sure
Thanks in advance everybody :SNSign:
eliteJAE
Stanford University
Dec 12, 2008
  • Dec 12, 2008
hows your operating temps? any loss of coolant? its probably nothing, but i got that sound when the water in my rad starting gurgling because of a bad cap/blown head gasket.
it could be a variety of things though, probably nothing major
PULMEOVR
I need a bigger E-Penis.
Sep 29, 2003
560
Ottawa, Ontario Canada
Dec 13, 2008
  • Dec 13, 2008
You can hear it from the interior? Does it sound like water running near the passenger side? That's what I hear in mine. I think it's normal. I wouldn't worry about it.
2003_GT
69
Santa Fe, NM
Dec 13, 2008
  • Dec 13, 2008
Ill check the cap and see if its ok, thanks for the replys just wanted to make sure the sound wasnt anything major
Mustang5L5
Mod Dude
Feb 18, 2001
43,361
18,106
224
Massachusetts
Dec 13, 2008
  • Dec 13, 2008
Mine did it. It's coolant bubbling in the heater core.
Mine did it since new, and did it still after two coolant flushes. I was positive i got all the air out and it still does it now and then.
2003_GT
69
Santa Fe, NM
Dec 13, 2008
  • Dec 13, 2008
so theres nothing to be done about it???
Mustang5L5
Mod Dude
Feb 18, 2001
43,361
18,106
224
Massachusetts
Dec 13, 2008
  • Dec 13, 2008
Not that i could find. Like i said, two coolant flushes and it still did it.
Smokeurhonda
457
Maryland
Dec 14, 2008
  • Dec 14, 2008
Yep, sounds like running water right after you shut off the car. I've got it too, I'm assuming it's in the hvac case. Seems to be normal
Mach 1 iac valve in a 4.6 gt
  • solodriverz
  • Jun 3, 2026
SN95 4.6L Mustang Tech Jun 5, 2026
squeak93
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
