is this odd
  • Thread starter Thread starter monk_byrd14
  • Start date Start date May 18, 2004
M
monk_byrd14
14
  • May 18, 2004
Today I was looking at my donor 89 gt and noticed that it did not have fog lights or a switch on the inside. Is this rare? It also has a sunroof is that rare?
_jb_
808
Michigan, Berrien County
May 18, 2004
  • May 18, 2004
Maybe it's not a true GT. All GT's came with foglights, and the sunroof is an option. My opinion is go to http://www.mustanggt.org/main.htm and enter the codes and it will tell you what the car is.
M
monk_byrd14
14
  • May 18, 2004
it is a real gt it has all the other signs that it is a real gt.
J
Js5ohLX
287
Ohio
May 18, 2004
  • May 18, 2004
Well, it's not hard to make a clone, a true gt will have the switch and fog lights.
88stangmangt
2,332
Stafford,VA
May 18, 2004
  • May 18, 2004
never seen a tru gt without fog's? does it even have the mounting cups? wire harnesses? if not it isnt a true gt i have also seen tons of gt's with sunroof's.
The Shape
2,224
East ARKANSAS Delta
May 18, 2004
  • May 18, 2004
Also weren't GT's the only ones with the low coolant light? That is another way to tell a true GT.
M
monk_byrd14
14
  • May 18, 2004
it does not have the mounting cups, wiring harness i don't know
The Shape
2,224
East ARKANSAS Delta
May 18, 2004
  • May 18, 2004
What about the low coolant light?
M
monk_byrd14
14
  • May 18, 2004
i checked the vin # and it is a real gt
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
May 19, 2004
#10
  • May 19, 2004
  • #10
Then the answer is: someone took them out and replaced the switch.
_jb_
808
May 19, 2004
#11
  • May 19, 2004
  • #11
Why would someone want to remove the lights though? Unless it's only for the strip I can see why then.
stangbear427
2,401
New England
May 19, 2004
#12
  • May 19, 2004
  • #12
Because they were notorious for overheating and melting the switch, causing it to do the copcar thing. Somebody just got tired of replacing the switch, fixing it, etc- and removed the temptation to switch them on... entirely.
_jb_
808
May 19, 2004
#13
  • May 19, 2004
  • #13
I've never had a problem with them and I use them everytime I drive. So far so good at least. I don't think anyone rewired them before me, and now I have them to run whenever the key is on.
mustang88GT
186
Charlotte, North Carolina
May 19, 2004
#14
  • May 19, 2004
  • #14
mine are gay they work for bout 2 min then all my lights turn off then back on... scared the ***** out of me when i first bought teh car and going on a counrty back road and all the lights cut out....
stangbear427
2,401
New England
May 20, 2004
#15
  • May 20, 2004
  • #15
Right. It sucks. JB, yours must have been owned by one of the few people who actually got a recall notice from Ford on it, or heard about it somehow and got it done. Consider yourself lucky.
K
knowlegeable1
107
Cali
May 20, 2004
#16
  • May 20, 2004
  • #16
mine does this as well. anyone know why?
ss93cobra
1,422
Wilmington NC
May 20, 2004
#17
  • May 20, 2004
  • #17
The factory switch can't handle the voltage draw from the fog lamps. Either wire the fog lights to a seperate switch ( www.corral.com tech article) or replace your existing switch with a new one and wait for it to do it again in a few years. If you replace the switch, take a good look at the harness plugs too.
stangbear427
2,401
New England
May 20, 2004
#18
  • May 20, 2004
  • #18
The actual upgrade from Ford came with a new headlight switch, multifunction switch, and a heavier gauge wire running between. Some years also needed a instrument panel dimmer switch. The repair kit from LRS comes with a new harness plug and terminal ends.
stang2004
177
Northern Jersey
May 20, 2004
#19
  • May 20, 2004
  • #19
i havent had any problems with my fogs, they switch on and off completely independent of my other lights. The dimmer switch however as i turn it, it makes the interior lighting flicker,, very strange
_jb_
808
May 20, 2004
#20
  • May 20, 2004
  • #20
Could be the switch is rusted or just worn out. Mine makes a sqeaking sound when I turn it. I also think the little dots are on the wrong side. The dots are larger towards the dimmer side.
Electrical Defrost switch ignition?
  • Teen'93stang5.0
  • May 16, 2026
Fox 5.0 Mustang Tech Jun 3, 2026
Teen'93stang5.0
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
Electrical Dash wiring
  • RileyDymond
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 19, 2026
RileyDymond
Fox Full set of seats in the back of a hatch
  • keel
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 31, 2026
keel
O
Suspension Extremely Quick / Light Steering
  • Okie
  • Oct 21, 2025
Fox 5.0 Mustang Tech Oct 22, 2025
AeroCoupe
