Isky Cam ?
  • Thread starter Thread starter Mopar1
  • Start date Start date Mar 15, 2008
M
Mopar1
61
Shelton, WA
Mar 15, 2008
  • Mar 15, 2008
Any feed back on anyone running this cam or comments in general.
http://store.summitracing.com/partde...5&autoview=sku
Intake Duration at 050 inch Lift: 210
Exhaust Duration at 050 inch Lift: 218
Duration at 050 inch Lift: 210 int./218 exh.
Advertised Intake Duration: 257
Advertised Exhaust Duration: 265
Advertised Duration: 257 int./265 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.480 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.500 in.
Valve Lift with Factory Rocker Arm Ratio: 0.480 int./0.500 exh. lift
Lobe Separation (degrees): 112
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Mar 15, 2008
  • Mar 15, 2008
My first thought is that seems like a pretty mild cam. Not a lot of duration on either lobe, and it only makes power to 5600 RPM. Your link doesn't work, by the way. Is this the cam you're referring to? http://store.summitracing.com/partdetail.asp?part=ISK-371257-265&autoview=sku
Edit: I also just noticed that it uses the 302 firing order, not the 5.0 HO/351W firing order. Is this going to be used with EFI? It won't work unless you can change the order that the injectors pulse somehow, without rewiring your harness.
7-UP BILL
885
My other car is a Firetruck
Mar 15, 2008
  • Mar 15, 2008
I have an Iskenderian cam in my car (custom grind) but it's close to this cam. Grind RR-265 HYD, RR-275 HYD. It makes great power and passes emissions here in NJ. (w/ smog pump) Idles real nice (slightly lopey) and goes to 6500.
Int lift .500
exh lift .520
lobe sep 112
cam is cut w/ 3* advance
M
Mopar1
61
Shelton, WA
Mar 15, 2008
  • Mar 15, 2008
I checked the application tab and it says its for 5.0L HO ??????
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
P
Cam spec
  • peter.farina
  • Nov 29, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 22, 2025
Ric4eyedFox
R
P
Cam spec
  • peter.farina
  • Oct 27, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2024
TOOLOW91
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
SBF Head Flow Table - Work in Progress
  • Noobz347
  • Sep 29, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 30, 2025
