it cranked
myboyhasa66
81
sooo i tried to crank it today. i was worried there it wouldnt even crank but it did. i have spark and the fuel pump does prime. i smell fuel but none is going to the fuel pressure guage. i have a feeling that i connected the return and other line backwards.
i didnt put them on so i dont know whats up with that but i will check i tomorrow and well see how it goes. i know i smell fuel maybe its just leaking so bad that its not getting to the rail. ill see tomorrow and write what i find.-marcin
i hope its not leaking bad enough you dont get any pressure to the rails.....you would be in serious trouble if so. check you reading at the schrader valve you only need 3 things for a motor to run spark,fuel,air so its easy to go from there.
yeah thats what i am going for and hoping for. i hope that its just leaking or theyre crossed but the fuel pump does prime and i smell fuel so i will have a little time to check it out tomorrow
