it runs!
j753303
73
28
28
MASS
so heres what i got
347 stock block w/ wiesco pistons right around 10.5-1
AFR 185cc cnc ported heads, scorpion 1.6 roller rockers, Holley Systemax 2 intake, port matched with a 75mm throttle body, 36lb. injectors and a 3.5" Anderson power pipe in the fender.
comp cams 282HR that is advanced 4 degrees
im running a gold box with the MS3 3.1.05 firmware and it starts and runs but i cant get my idle valve right and it oscillates a decent amount. This is a first run tune so anyone care to take a look at it and see anything way off?the spark and fuel tables are a mess because i was scrambling trying to get it to idle.
Thank You! im pumped to finally drive this thing soon! its been about 2 years in the making.
Have you tried changing the idle valve to inverted. That's what allowed me to get better control of it. A91what did it for me.
We have the same camshaft but I'm turbo and using TW heads, 42lb injectors, 75mm TB, and same intake as you.
