It sputters
02nightmaregt
To hell with your Mustang, I want to see your HOG!
Jul 1, 2007
513
Southern Indiana
Ok so since i had such great help (seriously) on my last problem i now need advice again. So while i was driving home for the 4th (im stationed in NC and live in IN) i was driving through the mountains and was going up an incline and started to accelerate but the car started to sputter and bog. I stopped and refeuled thinking maybe it was just bad gas, and started driving and i was fine for about an hour or 2 than started doing it again. Im back in NC now and its fine driving normal but when i give it more gas than normal it bogs and sputters. I recently seafoamed it, changed the oil, and cleaned the MAF sensor. I have no idea.
p1237 - fuel pump secondary circuit fault
off the top i know the other four are slow respose and lean codes for banks 1 & 2, i'm guessing your fuel pump is crapping out and maybe causing a lean condition but that's just a guess
I agree that it is best to SeaFoam just prior to oil change or plug change to eliminate any chance of contamination. But I think the risk is very low.
For the p1237 code you really need a ford scan tool where you can run a KOEO ( key on engine off) self test to see if this is a hard fault or a Continuous Memory stored code. If it is not present in the KOEO test then the fault is intermittent and then what you would do is monitor the FPM pid and watch the reading while you shake the wiring and tap the fuel tank ( this simulates road shock) If the value is 75% and stays there then that is the default the Pid will read while the fault is present. at other times it will read 50% or will move between 85 and 115%
The other 4 codes are slow response and sensor lean codes for both front 02 sensors. The car is probably running lean while the fuel pump problem is happening causing these other codes.
