Well things have been nuts...haven't even had a chance to touch or spend money on the new build up for the car. I graduate in Dec. so after that I will be able to thrash on the new set-up.
Basically the only things being reused is...front suspension, C4 tranny, converter, block, meter, lower/upper intake, PMS software management, fuel system...everything else will be new from the 302 supercharged motor I ran for years. I sold the T-trim and many other parts to build a solid hi-rev NA motor.
Combo: 347 (B50 block, DSS girdle, SCAT 4340 crank and rods, JE pistons...11.3:1), AFM cam (don't ask which one), AFR 205s, TFS R intake (might move to the new box upper later), Bassani stepped exhaust, good valve train....etc...etc... Will shift this motor at 7,000rpms w/ the stock OEM lifters and will run the same ETs my supercharged motor ran. All new trick rear suspension, weight drop all the goodies. The PMS will control is all....(might even control some nitrous later in life). I still have a lot of work to do but here are a few preliminary pics. If you have any question besides the cam feel free to ask. The heads are still at the shop so no longblock pics.
The pics are big so here are the links:
http://www.mustangmods.com/data/102/dscf0032.jpg
http://www.mustangmods.com/data/102/dscf0024.jpg
http://www.mustangmods.com/data/102/afr2056.jpg
(intake port)
http://www.mustangmods.com/data/102/afr2053.jpg
(exhaust port)
http://www.mustangmods.com/data/102/afr2052.jpg
More to come later folks.
Troy
(intake port)
(exhaust port)
Troy
