Its that time again
slow5.0gt
138
For an oil change... Ive searched around for a test that proved Royal Purple on top or close to the top of synthetic oils... :shrug: no such luck till i found this
http://www.animegame.com/cars/Oil Tests.pdf
Im surprised that Mobil 1 scored so low on the test.. I know most people on the forums use mobil 1 i believe...
But it still leads me to believe that the "good" things about royal purple are all hype... Ive only found 1 test by an independant lab that supported royal purple.
Anyone found a test where they test synthetics vs synthetics to find out where they ranked? A place that isnt tied into the company that is the winner of that oil test....
All I find are amsoil coming out on top... :P
I'm confused..... are you looking to prove that royal purple sux? or are you trying to find a good oil?
If it's a good oil your after, just buy what's most readily available and change your oil on a regular basis. I'll bet the bank (synthetic or regular) you never have an oil related failure.
I agree. I think too mana people put too much emphasis on certain oils and types. My stepdad swears by Royal Purple and has tons of miles to go with his claims but my Stang has had several different brands of syns over the years and 195K+ miles later it is doing great. My 97 Expedition has had a number of different brands and mostly dino oil as of late, still running great with 235K miles. The key is regular oil and filter changes, not the type or brand you put in it.
I only run conventional. I've never bought into the whole synthetic thing. There are plenty of 200K mile cars out there run on conventional oil.
My 20 year old Mustang has only run on conventional and every time i pull a head off the walls still have the factory crosshatching on them
Im rather just looking for sites that show comparative results of oil vs oil. royal purple being one of them because i currently use it but planning on switching to mobil 1 syn
That test is all well and good, but it is not indicative of the stresses inside your motor. The critical points are bearings. And there you have perfectly mated surfaces where the load is spread evenly, rather than focused on a single mis-matched contact surface.
Companies like SPF use that test to show they are better. Othere companies use a series of gears to show how their oil sticks to the gears better and transfers from gear-to-gear better.
But none of that says a thing about how it flows thru the motor and protects bearings that are made to be protected, rather than being made to abuse the oil in ways it was not designed or intended to be abused...
In short, take it all with a grain of salt. If you want to protect unmatched surfaces, then the test you quoted should guide you to choose the oil that would best do that. But it is unrelated to what goes on inside a well-designed motor. I have seen motors run with kerosene in them (minutes, not hours and not under load) to clean them out. With no damage. The test in the article you gave would flame up quickly. :)
Good bearing design and tight tolerances are a different animal from the test that was run.
I agree, that test is elementary and old as hell. It doesn't test for oxidation, foam resistance, corrosion classification or how it reacts to various forms of heat/contained (not local)pressure/abrasion and has a very small contact point - favoring a certain type of oil composition.
Hey guys, let make a slip and slide and test which oil allows a fat guy to slide the furthest!
I switched to RP recently, and it seemed ALOT thinner than the previous synthetics I've used. So far, it's worked well, but I haven't felt any noticeable "performance" increase on my 110k mile 4.6 :shrug: i'm probably gonna go back to cheaper synthetics after this batch :D
