Jack stands question
  • Thread starter Thread starter lgbnaf7
  • Start date Start date Dec 13, 2005
L
lgbnaf7
61
Tacoma Wa
Dec 13, 2005
  • Dec 13, 2005
Does anyone know where I can find that diagram of where to properly place Jackstands on a mustang tolift the whole car off the ground
88_GT_5_oh
Sportin' a turbo 5.0 in Canadistan
Jul 4, 2004
WPG/MB/CA
Dec 13, 2005
  • Dec 13, 2005
i put 2 under the rear axel, then 2 under the k member. make sure to have them as far apart (towardt he outside of the car) as you can
SamSnyder
196
  • Dec 13, 2005
Don't know if there's any "official" diagram of where to put them. What I do know is that the factory jacking points, at least on the 86-93 Fox, may not be the best place to support the car. They were on the unibody where the metal was thinner than on the frame rails. What do I do? On the rear, I use jackstands that have a round cutout on the top that pretty much matches the tube of the axle housing. That lets me place the stand anywhere from the center section, on outboard to the brake backing plate. Supporting it under the axle tube seems about as secure as you can get. The front is a little more of a problem. I go for the frame rails near where they turn upwards to follow the floorboards up to the firewall, obviously on the flat part, and not where it turns upwards. The problem here is that no good jackstands I have seen actually fit flush on the frame rails. I just aim to get as much jackstand under as much frame rail as I can. That's about all I can tell you.
88_GT_5_oh
Jul 4, 2004
WPG/MB/CA
Dec 13, 2005
  • Dec 13, 2005
yep. wheni am in a rush i do them onthe frame rails as well.
there is a nice place where the control arm meets the k member that put my stand under.
HISSIN50
34
129
Dec 13, 2005
  • Dec 13, 2005
Someone has posted a diagram of the proper jack points before - it might have been Don.
I always wondered what the recess in the mating surface of jack stands was made to meet with - it has not fit anything I have ever put a stand under very well at all.
Sam, as usual, has the right idea with how to possibly help that. Just make sure it is a secure junction.
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Dec 13, 2005
  • Dec 13, 2005
I like to place the jack stands as far out as I can get them on the A-arms up front so that I have all the room I need to work on the bottom of the motor.
Never use jacks on the factory jack points unless you have the area reinforced with some angle iron or sheet metal that will distribute the load. Using the jacking points will cause the floor pan to buckle and pinch your door shut! (NOT FUN!)
L
lgbnaf7
61
Tacoma Wa
Dec 13, 2005
  • Dec 13, 2005
Found It
http://forums.stangnet.com/attachment.php?attachmentid=38115&d=1126057032
DTT92LX
185
Downingtown, PA
Dec 13, 2005
  • Dec 13, 2005
When you put the stands on the frame rails, doesn't the front (from the rails forward) seem to sag down though? Like the engine/front end have too much weight out front of the stands. I put them under the rails once and got a bit nervous that I was bending up the car! I swear the nose sagged a good few inches once I let the car down on the stands.
D
Drivetrain car still rolling while in gear and off
  • dqureshi06
  • Jan 24, 2026
Fox 5.0 Mustang Tech Jan 24, 2026
General karthief
Electrical/engine bay harness questions
  • djj62478
  • May 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
djj62478
Electrical Diagrams
  • 3054tony
  • Jul 12, 2025
Fox 5.0 Mustang Tech Jul 17, 2025
M
Off-road h pipe
  • MadMatt7
  • Oct 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 10, 2026
nickyb
Resolved 83 alternator wiring harness
  • sparten5000
  • Aug 2, 2026
Fox 5.0 Mustang Tech Aug 23, 2026
limp
