Jake brake stang!!
92Kobra
Napavine, WA
I was getting on the freeway in my gt and as soon as i hit 3000rpm my car started cutting out and it sounded like a jake brake on a semi. So I got off the freeway and drove through town. Same thing ,everytime i would get up between 2500-3000. It also has a bouncy idol at a stop. anyone that can help out there?
The TFI module mounted on the distributor is usually the culprit for a high speed miss on a warm engine. If the problem does not occur when the engine is cold, the TFI module is definitely suspect. You may need a special socket to remove the TFI module, but most auto parts stores will have one for $5-$7.
Automotive Tools Specialty | Auto Mechanic & Technician Diagnostic, Testing Equipment | Thexton
Or you can grind down the outside of a 7/32" deep socket untill it fits.
See the "Surging Idle Checklist for help with all your idle/stall problems. Everything you need to find and fix idle problems is in there.
The first two posts contain all the updates to the fixes. At last count there were 24 possible causes and fixes for surging idle/stall problems. I continue to update it as more people post fixes or ask questions.
