JBA header help. dead in the water on pass side
MadMike1337
IM STUCK! i got the driver side bolted up now im having a problem with the pass side. how the hell do i get the new one in?! its immpossible!!! i got the old one out ok no problem. i removed the starter and MM with out any problems but when i go to put the new one in it gets stuck on the tranny where the starter bolts up and on the k looking thing.
any suggestions...
fyi: installing JBA shorties, i have a 08 gt 5spd
its not so much that i cant see its the fact that im getting hung up on the trans, the body of the car, and possibly the k member i have tried every direction possible. next option it so have it towed out of my garage on a flat bed
I put Ford Shorties on mine. I had to do as the other poster suggested, and disconnect the right motor mount and jack the motor up on that side. Pulling that wheel off isn't a bad idea either.
Good luck to you...
