jet chip and eec question
danmcc79
27
MS
I have had my jet powertech chip for a while now I took it out the other day and I think my car runs better and has more power without it,am I crazy or could it be running better without the chip?
Now an eec question,Iam changing my automatic tranny computer to a manual tranny computer,I installed a built aod and got rid of my trashed aode the question is will my car crank with the manual computer using the nuetral saftey switch wire for the automatic computer or will i have to invent some kind of clutch pedal position sensor wire to trick the manual computer so it will think the clutch is down so i can crank my car?
any help greatly appreciated thanks,Dan :shrug:
Dan
I don't doubt it a bit that you might not be able to tell a difference from that chip. Some chips have very little changed in them.
I'm don't know the answer to your auto to stick trans Q.
I do remember this Q being asked and talked about on the Corral about 2 to 3 weeks ago. You could aslo most likely find an answer at http://tweecer.oplnk.net/
Later
Grady
