Junkyard rack and pinion basic question
  • Thread starter Thread starter 1966ponyguy
  • Start date Start date Jul 1, 2007
1966ponyguy
33
Kentucky
Jul 1, 2007
  • Jul 1, 2007
OK, after some looking and much modifiting, I have a rack and pinion on my 66. More on the conversion after testing. Just a quick overview, I kept the rear steer, converted my column with a roller bearing on lower end where I cut off the steering box, use 2 u-joints and a short connecting shaft (8" or so). Seems like it is going to be a good conversion. Crossmember replaces the original front bolt-in crossmember with 2 additional holes drilled. My question is, normally, is the large or small port on the rack and pinion unit usually the pressure side. I didn't take pics and cannot remember.
Thanks
jikelly
20+ Year Stangneter
Jul 9, 2003
872
53
99
Lubbock Tx
Jul 2, 2007
  • Jul 2, 2007
Sounds like you're off to a good start. Sorry I can't answer your question though.
BlwnGazkit
153
Richmond, VA
Jul 2, 2007
  • Jul 2, 2007
The pressure line is the smaller of the two.
For the same flow rate if you reduce the diameter, you increase the pressure. It's the inverse if you increase the diameter.
CanyonCarver515
122
El Lay
Jul 2, 2007
  • Jul 2, 2007
Please take pictures of what you have done. It's interesting. And good luck with the rest of the build.
chepsk8
2,203
Easton, PA
Jul 2, 2007
  • Jul 2, 2007
We have many threads on this subject.
I did this back in 1999 on Chepie with a Taurus rack. It was in Mustang Illustrated. Who's rack did you use?
BlwnGazkit
153
Richmond, VA
Jul 2, 2007
  • Jul 2, 2007
Are there details floating around for the install you did?
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
Fox Alignment Suggestions
  • PonyGTrider
  • Jul 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 13, 2025
PonyGTrider
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
J
Hello all, I have returned from a hiatus... Update and Questions
  • JackH
  • Aug 13, 2025
1974 - 1978 Mustang II Talk & Tech Aug 15, 2025
JackH
J
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
