I just bought a 97 cobra, 120,000 miles. According to the blue book value I got a pretty decent deal (about $1000-2000 below book), but I knew this car had some issues and would be a bit of a project.
It creaks going over bumps and turning the steering wheel. Any suggestions as to the cause of this? I'm assuming steering rack bushings and control arm bushings.
The big issue I'm having, it shifts pretty good with the car off, but with the car running it's notchy into any gear, but especially a pain in second/reverse. Second gear pulls half way and stops then if you wait and pull a little harder will go in. Otherwise, it will grind.
Reverse is similar, but much more difficult to avoid grinding.
I have not changed the fluid yet, but I've been recommended the Pennzoil Synchromesh to help alleviate some of my problem.
Also, I talked to a transmission shop, he recommended a rebuild (but I wasn't sure if he was just trying to sell me on the idea) but he mentioned the price at $1200, much better than my 97 GT was quoted at ($2200+).
Any help on my issues and what else to expect would be greatly appreciated.
Btw, my car has no visible mods, and I'm pretty sure has spent it's life totally stock because it still has the factory plug wires.
