Just got my price quote from DSS Racing.....Tell me what you think
Chowder Head
155
Tampa, FL
Hey all they finally replied to me via e-mail and I'll post what they said.
_______________________________
Dear Mr. Bruno :
Please review the estimate below. We would suggest using slightly lower compression, about 9.25. If you put 10lbs of boost through this engine, you will probably have closer to 550hp, rather than 450. We use our DSS Pro-Lite pistons, which are much more streetable than the JE pistons. If tuned in right, this combination of parts makes a great street/strip car. Feel free to contact us if you have any questions.
We look forward to working with you.
Sincerely,
D.S.S.,Inc.
Estimate
Date
Estimate #
07/14/2004 3746
Name / Address
Michael Bruno
Project
Item Description Qty Cost Total
331SB2003 LC/TW DSS Forged Pro-Lite Max Quench reverse dome pistons, polished forged I-beam rods with ARP rod bolts, cast steel stroker crankshaft, balanced and blueprinted, assembled in a race prepped 302 block with the billet aluminum Main Support System installed 2,559.95 2,559.95
Twisted Wedge Highlift longblck LONGBLOCK UPGRADE: Trick Flow DSS/Twisted Wedge "High Lift" cylinder heads installed on a short block to make a long block. Includes Ford Racing or Trick Flow roller cam with Ford Racing lifters, DSS aluminum roller rockers, 4130 .080" wall seamless pushrods, ARP head bolts, Fel-Pro graphite gaskets, etc. 2,700.00 2,700.00
Upgraded Hyd. roller cam Upgrade from reg. hyd roller to premium hyd. roller camshaft listed below 100.00 100.00
Xtreme Turbo Stage 1 SBF Stage 1 Turbo Cam
216/216 @ .050" .544"/.544"
0.00 0.00
Power Package #1 302
224-41118 289/302 Standard Volume Oil Pump 1 40.00 40.00
M-6605-B302 Late model 302 HD Oil Pump Drive Shaft 1 24.95 24.95
Oil pump bolt kit SBF oil pump and pickup bolt kit 1 8.95 8.95
302auxgaskets Auxiliary gasket set for 302 engine 1 25.00 25.00
1250 Fel Pro intake set 1 24.95 24.95
1415 Fel Pro exhaust gaskets 1 24.95 24.95
M-6710-A50 302 One-Piece Rubber oil pan gasket 1 19.95 19.95
302 Package #1 discount 302 Package #1 discount -23.80 -23.80
Power Package #1 302 144.95 144.95
Power Package #2 302
208 28oz SFI SBF balancer 1 299.95 299.95
286501 SBF 157T (late model) SFI steel flywheel - 0, 28, or 50oz balance, replaceable friction surface 1 239.95 239.95
7005 5.0 Stroker Pro Tray Windage Tray 1 109.95 109.95
100-2801 ARP Flywheel bolts 7/16 x 1.00" 6pcs. 1 9.95 9.95
150-2501 ARP Balancer bolt 289-460 except 351C 1 19.95 19.95
302 Package #2 discount 302 Package #2 discount -64.75 -64.75
Power Package #2 302 615.00 615.00
OP7050
Low profile 7qt oil pan with pickup. Works with most short and longtube headers, includes baffled oil return hole 299.95 299.95
Thank you for your interest in our products. Here is the quote you requested.
Subtotal
$6,419.85
Sales Tax
(7.5%) $0.00
Total
$6,419.85
*Maybe a little hard to read, I tried to copy and paste this straight from the e-mail and this is the best I could do*
What got at me first is when I filled out the form I orginally said AFR 185 heads.
How much difference is there between those and the heads they put on the list?
Remember, I'm still shopping around so I would really appreciate all your opinions, feedback, suggestions, whatever. BTW, do you think this price is resonable or should I shop somewhere else? If I should go someplace different please provide a link to the company. Oh in case you didn't see, I was planning to do a 331 build with a possible turbo next year.
Thank you all!
What really sucks is how much of that is labor costs. Aside from the block machining and head work, you could build that motor yourself for a couple grand less just buying the parts. I myself havent learned enough to build a motor but if i had the cash i'd sure as hell try!
I wouldnt be surprised if a company would try to push certain products like those heads on customers if they can get them cheaper than what you want. Although, if they pay more they'd just charge you more, but you never know.
wut are you looking for i know where you can get a bored out 302 to 308 shipped for 900 has stock conecting rods and fedral mogeul bearins keith black pistons ect.306 for 800 both already built
Those arseholes are smokin crack.........no, sorry, whoever pays that much for an engine, they are smokin crack! What are they doing? Flying in a team of engineers from NASA?
I would bet the majority of their staff are : uneducated, young people making poor wages, they probably are doing the brunt of the work.....they may have a few qualified people around who double check things, but that ain't no custom race motor, nor is it a real custom build. Insane prices! :notnice:
