a dealer will bend you over to do it. i think you need to buy 2 quarts for the transmission, that shouldnt cost more than $12 if you are using a good synthetic fluid. i get coolant from costco for $13 for 2 gallons of prestone. you can add water wetter to it and thats about $7 a bottle. the diff fluid should cost about $7 a quart, so you need 4 of those. also there isnt a gasket on the diff cover so you either need to buy one, or make you own like the dealer will tell you to do with some black RTV. for the power steering, use mobil 1 synthetic ATF and you should get a few bottles of that to make sure it flushes completely. now if you did it at the dealer, they would charge you $130 to do the coolant flush, $130 to do the trans fluid change, probably $130 to change the diff fluid, and another $130 to flush the power steering fluid.
